Results 1 to 9 of 9
Thread: Competition department 85mm P&C value check
    Jan 2011
    Sunny Southern France
    Hello,
    another boring thread with a value check, but, I found something interesting local to me and I was wondering if it could be worth something.
    So, this is a set of PC, high compression ratio, bore 85mm
    Cylinders have the hard chrome plating they called Chromal in the past I think.
    Everything is supposed to be in very good condition.
    Comes with:
    Pistons
    Cylinders
    Rings
    pins
    A set of steel rods
    These parts were fitted to a carrera 6 engine which has been retrofitted with a 2.0 set of PC
    Here are some pics
    Thank you for any feedback!
    Happy new year from France
    Olivier
    Aug 2012
    France
    Hello Olvier.
    Great pieces for your project.
    Do you have any serial/part numbers to share marked on the P&C ? I would start to make sure those parts are real ones, or well built and used on a Carrera 6 engine / or R.
    Once done, a quality check of the parts needs to be done by a pro, and eventually the costs of the resto if possible.
    Then a price check might be carried on
    However, if these are Carrera 6 pieces, you know this is very rare and valuable, therefore very expensive.
    my 2 cents.
    Cheers
    Xavier
    O-G 26 - Early911S 2407
    Jan 2011
    Hi Xavier,
    thanks for the reply.
    I should have writtent somewhere "assuming they are within spec"
    They are not genuine carrera 6 parts, as 85mm with a 66 crank drives to something like 2.3l. The 906 were originally 2l , some cars are said to have been fitted with slightly bigger pistons (82 if I am not wrong) for hill climb purposes.
    To my knowledge this set is a bit strange... But some other will probably have much more informations!
    Olivier
    Before that set will be usable you need to see if you can still get the special rings required to seat in the hard chrome bores.
    Jan 2011
    Hi Ed, thanks for the answer.
    Pistons are coming with the rings. And they are supposed to have seen very little use...
    thx
    Olivier
    Jan 2011
    Back to the top.
    Anybody has even a rough idea please?
    I thought these parts were cool......
    Jul 2009
    Bordeaux FRANCE
    the bore of those parts ( cylinders and pistons)is not 85 mm diameter but 84 mm and they are already sold ( under compromise)
    cheers
    Aug 2012
    France
    Quote Originally Posted by jdj123 View Post
    cheers
    Would you enlight us about the origin of these parts ? This is for our culture only.
    All the best.
    Xavier
    Jan 2011
    So sad
    Thanks anyway!
  1. FS: New 85mm JE Pistons
    By Orbit in forum For Sale: 911 Parts
    Last Post: 03-16-2014, 01:35 PM
  2. SWB Competition Set-up Help
    By Fishcop in forum Technical Info
    Last Post: 03-12-2014, 03:38 PM
  3. Parts check in the 2.0 engine department!
    By mighty mouse in forum Technical Info
    Last Post: 11-14-2009, 03:18 PM
  4. 81mm and 85mm 911S Pistons
    By chris_seven in forum For Sale: 911 Parts
    Last Post: 11-10-2008, 10:49 PM
  5. Sam has competition
    By pwd72s in forum General Info
    Last Post: 01-20-2005, 11:42 PM
