Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Motor Mounts
    Motor Mounts
    I am looking for some slightly stiffer motor mounts. The p/n for the "cab" mounts is 911-375-043-07. My problem is that prices range from $21 each to over $102.
    I see various brands too -- Rein, Hamburg Technic, and "German." The $102 are at Stoddard and lay claim to Porsche Classic Parts.
    Is there ANY functional difference among this widely priced array of parts?? They all look stock to me, but I am not going to use a concours magnifier. I just care about function.
    Apr 2011
    N.Calif., south of SF
    What year/model are you inquiring about? Also, have you considered replacing the transmission mounts at the same time? I am looking into the same for my '73.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    It has a 915 trans.
    Yes, I hear you should put the stiffer mounts up front at the transmission.
    Sep 2006
    Eagle, Idaho
    I would strongly recommend WEVO "black" motor mounts at all 4 corners.
    Designed for sporty road use, yet suitable for light occasional track use.
    Approx. US. $80.00 per unit.
    Long life, excellent performance, easy to install, no perceptible difference in noise / vibration, improves shifting.
    JZG
    Atlanta, GA
    Quote Originally Posted by John Z Goriup View Post
    JZG
    John, what if your a concours Wennie and care about maintaining a stock appearance? Thanks, Mark
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Sep 2006
    Eagle, Idaho
    Quote Originally Posted by merbesfield View Post
    A 2-part answer, Mark, and a disclaimer that my answer is based solely on my personal experience with my car and its particular set-up ( '70 911T with 3.0 liter, Webers, SSIs and 915 with Rennshift ) with which I am extremely satisfied. I'm sure any number of pros among our membership could offer far more experiences based on their many installations and combinations of parts and performance.
    A. The OP indicated he wouldn't be using a 'Concours magnifier' and was primarily concerned with function...…a view which I feel favors the WEVO mounts by virtue of their vibration & noise control and effective reduction of engine/transmission movement.
    B. If it's gotta be and look absolutely original however, I don't think you really have many options……….. you concentrate on what looks original & replace your worn mounts with original, identical Porsche OEM units.
    The only option I can think of which would look completely original while offering a slight increase in performance are Porsche Sports mounts for 911s, which look exactly like the original items, are available from the factory, and stiffen things up somewhat. I initially installed these and put about 3,500 miles on that set-up - but I still replaced them with the WEVO "black" mounts after I rode in a WEVO-mount equipped '73 hot-rod with a 3.0 liter aluminum case engine / transmission, exactly like mine, because I was impressed with the improvement in vibration and shifting.
    JZG
    I have used the Hamburg Technic Cabriolet Mounts from Deutsche Parts for about 6 years and have been please with them in terms of both stiffness and NVH.
    The price is not too bad and so far we have not had to replace any of the mounts we have fitted (over 50 pairs now).
    Atlanta, GA
    I have never replaced motor mounts before. Are they hard to do? Any tricks needed?
    Just curious. The mounts on my 66 look very old, prob original. How important are mounts to the the overall performance and operation?
    If these are easy to replace, is the performance increase from a mount like the Hamburg Technic that Chris mentions vs those WEVO black that John mention worth the effort/money to go with one vs the other and swap out later for an original look?
    Mark Erbesfield
    1957 356A #58648
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    There are several good reasons for stiffer drivetrain mounts. IMHO, a main reason for having stiffer motor/trans mounts is to keep the drive train in the same spot all the time, even when the car is under intense lateral load, or when the drivetrain itself would otherwise be moving violently, like under hard braking while on a bumpy surface, or when downshifting while cresting a sharp hill. Keeping the drivetrain in-place makes for a more positive and direct connection through the shift rod and shift linkage to the transaxle. This makes it easier for your hand to always "know" where the gears are.
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    Feb 2010
    San Francisco, CA
    Swapping out the motor and trans carrier mounts is a simple job. I highly reccommend it as you feel pretty sattisfied after a small amount of work.
    I replaced my worn stock units with Porsche "Sport" mounts a while back. I also flipped over the big cup washers on the motor mounts as someone once told me that this stiffens up the mount a little. I've been really happy with the setup.
    During one of those down times where the mind wanders and you start thinking of unnessicary work that you want to do on the car, I got it in my mind that I needed to swap in some WEVO mounts. After chatting with Hayden (Herr WEVO) for some time, he advised that I wasn't going to see much of an improvement over fresh "sport" stock mounts. $$$ saved
    I did install the WEVO shift coupler, which transformed my shift linkage and since it's hidden from view, the originality obsessed aren't bothered by it.
    The WEVO mounts look awesome and I've never heard any complaints about them. I'd use these if I were building a hot rod.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. Split graphite motor/trans mounts?
    By Christian Guthrie in forum Technical Info
    Last Post: 01-15-2014, 04:11 PM
  2. FS: Solid Motor/Trans Mounts
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 10-29-2011, 05:41 PM
  3. New motor/trans mounts = Better shifting
    By EsGeht in forum Technical Info
    Last Post: 04-05-2010, 01:51 PM
  4. Transmission Support and Motor Mounts
    Last Post: 07-15-2009, 09:27 AM
