Results 1 to 10 of 15
Thread: Removing trolley jack dents in floorpan and replacement seat belt warning lamp cable?
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    I've stripped out my '72 911T cabin and found that at some point in its life, the floor has been pushed up under each seat about an inch by jacking up the car in the middle of the floor pan.
    Anyone have any tips on how to remove these dents at home, or will this need professional bodyshop attention?
    Also, the passenger side seat belt warning light cable is missing, a quick search of Pelican, eBay, Stoddards and SMC failed to turn them up. Does anyone have the part number or suppliers for these?
    Name:  Floorpan dents 2.jpg
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    Dec 2008
    Woodland Hills, CA
    Floor dents: I would suggest using a body hammer from the top while utilizing a dolly from the bottom side. Less cosmetic damage that way. If you can't reach both areas with each hand yourself, you may need a partner to assist you.
    Feb 2005
    Lake Tapps, WA
    Rubber mallet
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Mar 2013
    I've tried a large rubber mallet, but the floor just bounces without seeming to stay down. I was wondering if there is a method of pulling the floor down somehow? I'd prefer not to drill holes, as my floor is original and completely rust-free.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    Feb 2005
    Lake Tapps, WA
    Hit it pretty damn hard. Use your big muscles
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Senior Member CidTito's Avatar
    Jan 2008
    Emeryville, California
    Quote Originally Posted by endo911rs View Post
    - add a 2 1/2 lbs weight (like duct tape a medium sized bean bag) on the end of the mallet to give you a bit more downward mass on a down
    swing... Practice on a piece of 2 x 4 to help you with some control but yet give you a nice thud.
    E911SR #2107
    69 911T/S SWT 3.2L
    RG #384
    Not a rubber mallet, you need what's called a "dead blow" its a weighted composition mallet, it won't bounce back on you.
    In other words, it is filled with sand or steel shot.
    Feb 2005
    Lake Tapps, WA
    Yep, that's what I have. Works great.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
    Jul 2006
    Corvallis, OR
    A 4X4 or larger works well. You can put a towel under it also. Wood is good.
    72S, 72T now ST
  1. WTB: 1972 911 Seat belt warning relay
    By SpawnyWhippet in forum For Sale: 911 Parts
    Last Post: 02-14-2014, 01:15 PM
  2. WTB: 1972 911 Seat belt warning lamp harness / cable
    Last Post: 01-07-2014, 04:48 PM
  3. Replies: 0
    Last Post: 01-06-2014, 04:29 PM
  4. WTB: Fasten Seat Belt warning light
    By merbesfield in forum For Sale: 911 Parts
    Last Post: 05-30-2011, 05:49 AM
  5. Sport seat belt warning light
    By 73point5 in forum Technical Info
    Last Post: 08-19-2002, 02:07 AM
