Results 1 to 7 of 7
Thread: Oil pressure relief mods and measurements ('67)
    Nov 2006
    S. F. Bay Area
    Been over a year, and I forgot…
    Had oil pressure relief mods done to case, have parts, not sure what spring goes where, etc. Also,
    Trying to ensure that old pistons are out, and have measured depth to the "step". Can anyone verify these measurements? Appreciate it.
    Brian
    S Reg #1032
    I compiled everything I could find here
    http://forums.pelicanparts.com/911-e...ve-thread.html
    Nov 2006
    S. F. Bay Area
    What?….That's it?…….that's all you got??
    John, thanks, as always!!!
    Brian
    S Reg #1032
    The way I've always used to remove a stuck piston is to insert a taper tap that will start to screw into the piston, when the threads grab enough twist and pull out.
    Nov 2006
    S. F. Bay Area
    Ed, makes sense.
    For now, I'm just trying to verify that I don't have one left down in the bore. I can only find one of my old pistons…...
    Brian
    S Reg #1032
    stick a magnet down the hole if it sticks, there is a piston in the bore.
    Nov 2006
    S. F. Bay Area
    Gled…….well done! thanks
    Brian
    S Reg #1032
  1. WTB: '67 911 sump plate and o.p relief plugs
    By Silverbullit in forum For Sale: 911 Parts
    Last Post: 07-09-2013, 02:14 PM
  2. RSR oil pressure relief valve
    By Wild Bill in forum Technical Info
    Last Post: 12-21-2010, 11:50 AM
  3. FS: Vintage Oil Pressure Relief Valve Replicas
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 08-27-2010, 04:59 PM
  4. FS: 2.8RSR Oil Pressure Relief Valve
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 06-25-2008, 11:53 AM
  5. 1977 911S Ebay (Comic Relief)
    By creator8 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-23-2006, 11:07 AM
