Thread: Bolt size for center rear license panel
    Atlanta, GA
    Silly little question, but what size and type bolt and nut are used to attach the center panel to the left and right bumperettes? Just below the bumperettes and at bottom of panel.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Mark, there is a speed nut clipped to the bumper, and then a hex head (about 5mm screw, 10mm hex size) ) sheet metal screw and back up washer is installed from the license panel towards the bumper. If need be spacer washers are installed between the license panel and bumper to maintain a consistant gap. I use a 10mm 1/4" drive u-joint socket with a 14" extension so I can turn the bolt with the muffler installed.
    Atlanta, GA
    Would these be the same size as the fender mount bolts and speed nuts? Or smaller?
    Mark Erbesfield
    1957 356A #58648
    Yes, they are the same as the fender mount.
  1. FS: Rear Bumper Center License Plate Panel - Early LWB 911
    By m1franck in forum For Sale: 911 Parts
    Last Post: 09-22-2013, 02:23 PM
  2. Replies: 5
    Last Post: 12-18-2012, 07:37 PM
  3. WTB: rear license panel and license plate lights
    By loopie in forum For Sale: 911 Parts
    Last Post: 10-26-2012, 04:16 AM
  4. WTB: rear center panel for 72'
    By chrisfreed1 in forum For Sale: 911 Parts
    Last Post: 06-03-2012, 01:30 PM
