Thread: 73 S - fuel tank question...
    Given the scope and cost of the resto I'm doing on my 73S, replacing the fuel tank seems like well-spent money. In looking at Porsche's PET resource, I see (3) part numbers - two for 62L tanks, and one for an 85L tank (seems to be 1973 on). My parts guy is asking me which one I have. While I suspect 62 liters, can anyone definitively tell me which tank is the correct stock replacement. If it helps, I found the following part numbers in PET:
    901-201-010-22 (62L that lists up to 71 and then 72 on?)
    911-201-101-25 (62L that shows 72 on)
    911-201-010-00 (85L 73 on)
    Thanks!
    If your S is a euro/row spec it should have the plastic 85L tank.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Thank you - it is a USA car, but that still apparently leaves TWO choices for the 62L tanks per my above posting/parts numbers from PET??
    72 on I think would be correct
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    Senior Member Per Schroeder's Avatar
    Mar 2013
    Avon Lake, Ohio
    You've got the part number wrong on the second one. 911-201-010-25 is listed as T/K, which I would believe would be the 73.5 CIS tank.
    Ergo, you need the 901-201-010-22
    Per Schroeder
    Aug 2005
    VA
    72. Just check that it is for the full size spare tire....not the space saver as on later cars
    Chris
    73 911 E
  1. 120 liter fuel tank question
    By cscrogham in forum General Info
    Last Post: 08-04-2013, 02:35 AM
  2. Fuel Tank Sending Unit Failure Mode Question
    By bobmagyar in forum Technical Info
    Last Post: 06-24-2013, 03:13 PM
  3. '73 Fuel Tank Question
    By kh911 in forum Technical Info
    Last Post: 05-18-2011, 04:54 AM
  4. Fuel tank question - 911E/911S vs. 911T
    By obrut in forum Technical Info
    Last Post: 12-16-2008, 06:26 AM
  5. '68 911 fuel tank vent pipes question...
    By 72tii in forum Technical Info
    Last Post: 01-29-2006, 02:17 PM
