Results 1 to 9 of 9
Thread: Use of anti seize during reassmbly
    Lots of threads discussing anti seize on wheel studs, but I couldn't find anything about using it during general reassembly. I'm refitting the rear bumper trim strips today, and wondered if a dab on the studs might help protect from rust long term. Thoughts?
    1973 S Targa #0098
    Member # 1498
    I use anti-seize on almost all under car fasteners, besides preventing fasteners from rusting together it also allows for easier assembly of nuts and bolts as they screw together easier than dry threads.
    Oct 2005
    Minneapolis, MN
    It's all about anti-seize!
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Apr 2011
    N.Calif., south of SF
    From the SAF-T-EZE site-
    Anti-Seize and Lubricants
    High Temperature Anti-Seize And Extreme Pressure Lubricant Compounds
    Use SAF-T-EZE® Anti-Seize for Ultimate Protection and be assured you can take things apart Safely - with Ease.
    SAF-T-EZE® Anti-Seize is compounded from fine metallic particles and graphite in a heat resistant lubricant. This combination results in extreme pressure lubricating properties that prevent galling and cold welding, and at the same time resist water wash out or galvanic pitting and corrosion from road salt, acid rain or salt water.
    SAF-T-EZE® Anti-Seize compounds do not cake or coke. Particles present will not evaporate at extreme temperatures and their heat resistant properties prevent carbon fusion and seizure to temperatures of 2600ºF. SAF-T-EZE® Anti-Seize compounds provide maximum bolt tension from minimum wrench torque. In fact, at least 20 percent less torque is required to get the prescribed tension than with dry parts.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Thanks all - I suspected it a good idea, but thought it good to let experts confirm.
    1973 S Targa #0098
    Member # 1498
    Dec 2008
    Woodland Hills, CA
    I use it on the brake pad retaining pins.
    mad scientist
    Apr 2007
    Austin, TX
    I, like most others whom already responded, use it on any fastener that is outside the car or potentially exposed to elements. Makes it easier to remove the next time.
    1971 911T SWT - Sun and Fun Machine
    1972 911T - "Minne" painted and undergoing assembly.
    Atlanta, GA
    Definitely recommend anti seize on bolts out side car. Another tip is before reassembly take the bolt to the bench grinder with a wire wheel and clean all the old rust and crude out of the threads and hit the screw cap at same time. If hole was really cruddy, run a tap through it. This along w anti seize will make it all go back together much easier. Yes it is a little time consuming but it's all in the details. Take your time and enjoy.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    I guess I am an outlaw then (just like my car). I just tighten or torque the fastener, and squirt a little Green (wick in) Loctite on there after I have it torqued. I also have a bad case of OCD and remove, then re-tighten, the fasteners on my car every few decades.
  1. Anti-seize on Fuchs wheels?
    By davewadd in forum Technical Info
    Last Post: 07-15-2015, 06:12 AM
  2. SWB Anti Roll Bar Console Mount
    By 50/50 in forum Technical Info
    Last Post: 02-17-2012, 11:02 AM
  3. 15 vs 16 mm rear anti-sway bar
    By Neil '67 911S in forum Technical Info
    Last Post: 05-08-2009, 01:19 PM
  4. WTB: RSR anti sway bar arms
    By Mike_Moore in forum For Sale: 911 Parts
    Last Post: 11-25-2008, 09:20 AM
  5. Anti-Theft Devices - Need Advice
    By Mike Baum in forum General Info
    Last Post: 09-01-2005, 04:56 PM
