Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Are '65 and '68 brakes the same?
    Oct 2009
    Indiana
    Does anyone know whether the brake rotors, spacers, backing plates, etc., changed between 1965 and the late-'67/early-'68 model years?
    I suspect that my (August '67 build) '68 will need new rotors and I'm trying to determine whether I can search for other years.
    Any shared wisdom would be appreciated.
    Thank you.
    Oct 2010
    Stockholm/Sweden
    I believe the 68- cars had 7mm wider hubs in front and a 7mm spacer in the rear.
    Came with the switch to 5,5" wheels
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    The discs are basically the same if they are solid discs on the 67/68 car rather than vented as the back plates differ on the front. The solid front disc was used on the T up to 1969.
    A Programme Cars also had a thin spacer screwed to the rear disc.
    The piston diameter on the rear calipers may also change as the 65 car had 35m dia piston and by 68 they were 38mm dia.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by chris_seven View Post
    The piston diameter of the front and rear calipers is the same through the 68 (SWB) year model cars. The calipers changed a bit in appearance but not in function or fit.
    Jim
    Jim
    You, sir, are a wealth of knowledge...
    Peter Kane
    '72 911S Targa
    Jim,
    I am not sure what you mean.
    Fronts were always 48mm dia pistons right through to 3.3 Turbo.
    Rear pistons were initially 35mm and I am not sure when they changed but when cars had solid discs it was around 1967/68
    The 67 MY 911S with vented discs had 38mm pistons.
    The T with solid discs also had 38mm pistons by 1969.
    Sep 2006
    La Quinta
    I'm thinking the front hubs on a '67 are a little wider than on a '65. Anyone know for sure?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Aug 2009
    SF Bay Area
    Jim,
    Chris
    The rear pistons changed to 38 mm with the change from SWB to LWB. All SWB cars, with solid rotors had 35mm rear pistons and rear calipers with external cross over fluid pipes. You are correct, I should have mentioned that 67Ss and 68Ls and Ss had special rear calipers with 38mm pistons, external cross overs and spacers for vented rotors. 69 912s and 911Ts had rear calipers with 38mm pistons, soloid rotors and internal crossover passageways along with different bolt spacing.
    Jim
    PS: The original question was dealing with 65 to 68 rotors. That question has been answered previously. They are the same.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by John Straub View Post
    They got wider in the 68YM cars along with the increase in wheel width. The rear hubs got a 8mm spacer added during the 68 ym .
    Ciao
    Jim
    Dec 2008
    Woodland Hills, CA
    A little off topic...Do the front backing plates differ from vented to non vented rotors?
  1. Replies: 43
    Last Post: 01-16-2014, 03:10 PM
  2. Replies: 11
    Last Post: 12-10-2012, 02:58 PM
  3. Brakes, which way to go
    By Max (SD) in forum Technical Info
    Last Post: 07-14-2011, 10:21 AM
  4. Who wants some SWB big brakes?
    By mjmoran in forum Technical Info
    Last Post: 12-22-2009, 12:01 PM
  5. Brakes For '67 911
    By jaudette3 in forum Technical Info
    Last Post: 08-11-2006, 07:33 PM
