Results 1 to 8 of 8
Thread: Rear hub removal
    Dec 2011
    Victorville CA
    Rear hub removal
    I'm replacing my wheel studs and replacing with longer ones for spacers and I'm having some difficulty removing the castellated nut to remove the hub. I've wedged an iron stake between the existing studs and the ground but cannot get it to move. Thanks
    Nov 2002
    Fremont, CA
    It's torqued to ~340# . An impact wrench and some Gibbs oil will do the trick
    scott kinder
    kindersport@gmail.com
    Registry #614
    Dec 2011
    Victorville CA
    I've never had the hubs off before. After removing the nut does the hub just come off by itself or is there anything connected behind it to remove? I've already noticed a broken part on the ebrake.
    The piece of metal that wedges to the lower circular piece was broken off.
    Nov 2002
    Fremont, CA
    The castle nut is what retains the axle to the hub.
    To remove the hub, you will need to press it out of the trailing arm (requires removal of the trailing arm) OR you need a good sized (~10 lb.) slide hammer. Porsche sells a tool for this; here's a facsimile someone sells for a lot less:
    http://www.arnnworx.com/RearBearings.htm
    Here's a link to more info (there is a lot more on Pelican):
    http://forums.pelicanparts.com/porsc...placement.html
    By removing the hubs, you will destroy your wheel bearings. The inner race typically rips out of the bearing, which then again necessitates the use of a press or slide hammer to remove the outer portion of the bearing.
    Reinstallation of new wheel bearings should ONLY be done with a press (not a slide hammer). This will require removal of the trailing arm from the car so that you can set them up on a press.
    In case you were not aware, this is one of the more annoying jobs to do in the repair of your Porsche. Good luck.
    scott kinder
    Registry #614
    Dec 2011
    Victorville CA
    Just to switch out the studs? Is there another way to exchange out the studs without removing the hub?
    You can also remove the park brake cable and R & R studs through that hole without removing the hub.
    Dec 2011
    Victorville CA
    Thanks Ed, whew! Thought I was gonna be selling spacers there for a minute. How are the studs removed? Punched out? I've read that you can re-install the studs with a socket as a spacer and torque in with a regular steel lug nut but the removal I'm not too sure how.
    We just use a air hammer with a blunt tip installed, drives them right out.
  1. Rear radius arm removal
    By plumber in forum Technical Info
    Last Post: 04-12-2011, 08:20 AM
  2. Front and rear glass removal
    By cmcfaul in forum Technical Info
    Last Post: 06-21-2010, 07:28 AM
  3. Rear quarter panel removal
    Last Post: 03-25-2009, 12:53 PM
  4. help! removal of rear window Targa
    By EARLY911ZOO in forum Technical Info
    Last Post: 07-10-2008, 06:20 AM
  5. Targa Rear Window Removal
    By eaglenav1 in forum Technical Info
    Last Post: 05-30-2001, 12:24 PM
