Thread: Body #
    Body #
    Hi
    After doing much research on a car I have a question is the body # and the vin one in the same or is the body number independent of the vin and if so where do you find it.
    Thanks Bret
    Oct 2008
    Burford, ON, Canada
    There are three possible body #'s on the 911 & 912. The important one is the VIN. The VIN is stamped into the front trunk sheet metal, stamped into the aluminum manufacturers tag riveted in the front trunk area, and stamped on the paint tag until the end of 1968 production. The VIN can be found stamped into the lower dash frame under the knee pad & below the radio opening, plus written in grease pencil on the top of the dash under the dash pad in the left corner; this also only on the SWB cars. The LWB cars got a production number stamped in the lower dash frame and written in grease pencil. Karmann bodied cars got a third identification # that paralleled the VIN but was generally not the same for the SWB cars. For the LWB cars it was similar to the production #, and at some point seems to begin matching the production #. Very early 912 had the Karmann # on top of the dash in the speaker recess, but it quickly moved to the tunnel where it can be found just under the access panel at the rear.
    Hi Dave
    Thanks for the response, I am going to keep digging. Did you get your pm
    Thanks Bret
  1. WTB 2.0 or 2.2 MFI THROTTLE BODY
    By Dswanny1 in forum For Sale: 911 Parts
    Last Post: 11-12-2012, 09:34 AM
  2. Any body know weltmiester
    By lemonlib in forum General Info
    Last Post: 08-30-2012, 05:53 PM
  3. Body Panals Pre 69 SWB
    By visualfx in forum Technical Info
    Last Post: 10-10-2010, 02:13 PM
  4. SWB S Body Tag
    By Larryg57 in forum For Sale: 911 Parts
    Last Post: 09-30-2009, 06:22 PM
  5. Any body have...
    Last Post: 05-24-2005, 09:53 AM
