Results 1 to 7 of 7
Thread: I am puzzled: 1969 911E - How many temperature switches?
    Apr 2007
    Slovakia
    A friend of mine works on his 911E motor. He found 2 temperature switches on his breather cover on top of the case. Any catalog we looked up show just one temp. switch, but he found 2 there, both wired:
    One is Porsche part 911 617 117 00, the second is VDO part, but apart from the different temp. range on their respective bodies they look same. One of them is dead now.
    On top of it, wiring diagram shows 2 temp switches (start, start assist).
    Any other early 911 motor I looked at has just one switch sitting on this cover, so is this some '69 oddity, or someone drilled and threaded second hole for a new switch when the old one gave up? If so, where should I look for temperature switch (start) and temperature switch (start assist)?
    Thanks a lot,
    Martin
    It's a '69 thing. One year only related to the cold start system. Hold on and I'll get you the other part number.
    911 617 113 00 is the second switch.
    I always substitute a single late model thermo-time-switch (+45*) and use it to activate the cold start solenoid (the upper one on the MFI pump). The original ones at +10*and -10* are too cold and won't operate at normal temperatures. I believe the spray tubes in the air filter housing are a fire danger and should be avoided if you can. I install the new switch to operate the cold start solenoid and dummy the other. Gled
    Apr 2007
    Slovakia
    Thank you both Gled and LiveFromNY, it is clearer now,
    Martin
    I source the 45* switch from CIS 911’s that we’re located in the drivers side chain cover, from 74->. Same function, cold start thermo-time switch.
    Oct 2010
    Southern Ca.
    I hope you follow gled49's info , spot on !
  1. WTB: Porsche 911/912 NOS dash switches - 1968/1969 application
    By Hangman in forum For Sale: 911 Parts
    Last Post: 08-06-2013, 08:12 AM
  2. Early 911 1969-73 fog light switches
    By pkg911 in forum For Sale: 911 Parts
    Last Post: 09-26-2012, 11:26 AM
  3. WTB Correct Oil Temperature, Fuel and Clock Gauge for 1969 S
    By nammon in forum For Sale: 911 Parts
    Last Post: 08-06-2011, 01:22 AM
  4. 1969 911e
    By Nycarrera in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-03-2011, 07:57 AM
  5. 1969 911e
    By toomany911's in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 12-07-2006, 09:53 AM
Tags for this Thread
