Results 1 to 7 of 7
Thread: E Brake part
    Dec 2011
    Victorville CA
    E Brake part
    When I pulled my rear rotors my passenger side EB was missing a piece. I have never had the EB opened up so am not aware what it's actually called. It's one of two metal pieces that wedge under the knob. Do they still make parts for the brakes other than the pads.
    Name:  emergency brake 1.jpg
    Name:  emergency brake 2.jpg
    Port Macquarie, Australia
    I refer to that part as a "bow" for want of a better term. I replaced mine recently, http://www.sierramadrecollection.com..._detail&p=9214
    John Forcier
    EarlyS #1987
    Restoration Saga
    Dec 2011
    Victorville CA
    Thanks for the lead. The bottom piece must have broke off. I guess that means my drivers side was the only one that functioned since the brake was working.
    That piece had to go somewhere. You find it?
    Sometimes you can put them back together...
    -Marco
    TLG Auto: Website
    Dec 2011
    Victorville CA
    I found it but it looks broken off. I s that one piece top and bottom. I haven't removed other rotor yet
    There are 4 of those bows per car. Your picture shows the outside one. There are 2 for the left and 2 for the right. The legs of the bows go under the pegs on the brake shoes. So on the left side brake all 4 legs of the 2 bows have to be under the pegs. As you progress thru the installation confirm position of the 4 legs. Then adjust the shoes, then the cables with nuts + jam nuts. Its not easy, takes a little time to get it right. Gled
    Dec 2011
    Victorville CA
    Thanks guys. More questions to come I'm sure.
  1. Brake Rotors - Part 3
    By Richardnew in forum Technical Info
    Last Post: 01-09-2014, 04:23 AM
  2. Brake Rotors - Part 1
    Last Post: 03-03-2013, 12:56 PM
  3. Replies: 3
    Last Post: 04-22-2012, 06:07 PM
  4. Brake line installation - I get the right part?
    By cmcfaul in forum Technical Info
    Last Post: 04-28-2009, 10:43 AM
  5. Replies: 2
    Last Post: 07-18-2008, 06:11 AM
