Results 1 to 9 of 9
Thread: What next to make .... ST-classic
    Sep 2008
    Auckland , New Zealand
    Hi Guys ,
    While i'm in the groove and making new items for our cars i need input for future items that are wanted out there .... we have the 100ltr y straps soon , i plan to make a few tool roll straps with a twist to match the y straps and i can make any other leather items to suit .
    I am working with a retired fiberglass gruru who built americas cup boats and has been in the industry since early 70's , we are looking to do a range of amber /sq weave cover parts to give that porsche factory race dept look
    over Christmas with my race car engineer we designed up a ST look engine skid plate / front fuel tank skid plate and some other trick stuff..
    So what next , give me some ideas . As noted with member Gregbus members that help in mocking / making items get a finished item for free .
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    John:
    You might think about making the aluminum straps for holding in the rear plexi windows, and the front windscreen tabs. Brackets to mount CIBIE Oscars through the horn grill screwing into the battery boxes. I have dimensions for these brackets. Screen covers for the rectangular ST openings in the front air dam, and a custom screen for rear deck lids made from the same mesh material. End pieces for rear bumper ends which are mounted without bumperettes. Just a few ideas....
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Sep 2008
    Hi Gib,
    cheers for the reply
    all good ideas , let see
    - aluminum straps for holding in the rear plexi windows, and the front windscreen tabs - weren't these already made by someone like patrick motorsport? i'll check but sure they are already there.
    -Brackets to mount CIBIE Oscars through the horn grill screwing into the battery boxes. I have dimensions for these brackets. - sounds good send me the details , guessing that due to the weight of the lights the brackets are pretty solid
    -Screen covers for the rectangular ST openings in the front air dam, and a custom screen for rear deck lids made from the same mesh material. - i have the mesh for these but was having trouble shaping the material and keeping it correct . i will look into it again
    - End pieces for rear bumper ends which are mounted without bumperettes. - that's easy just a lasercut item. are these all weld on or tabbed to screw into place ?
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Aug 2012
    France
    John,
    If I may,
    +1 R type engine grill
    +1 for the aluminium straps for rear screen
    Brackets to mount brakefluid bottle overflow (with the bottle)
    Bracket to mount fuel pump in the front hood (near the smuggler box
    Would be cool to have another source for solid Marchal/Cibie Pallas headlight covers.
    Cheers
    O-G 26 - Early911S 2407
    Sep 2008
    cheers , great info and ideas
    Brackets to mount brakefluid bottle overflow (with the bottle) - i have been working on that with twin coil and fuel pump mounts
    Would be cool to have another source for solid Marchal/Cibie Pallas headlight covers.[/B] these can be made the same way as i do the coverplates , spun ali , but the rubber /catch and painting correctly is tricky to source . i have a couple of sets so will see who can make what .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    one thing to note , i have a guy that makes gaskets for me from his home, he is setup with all the cool gear and is a specialist making one off's / high performance / NLA stuff for alot of rare race cars / marques etc...in new zealand . Is there any thing in this line that is not available for porsche cars or aftermarket parts
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member uptheorg's Avatar
    Apr 2012
    Scarsdale, New York
    Quote Originally Posted by advtracing View Post
    . . . a custom screen for rear deck lids made from the same mesh material. - i have the mesh for these but was having trouble shaping the material and keeping it correct . i will look into it again
    You might want to look at D-Zug Produkte == they are distributing a piece for this function
    RennGrille
    Jim
    Jim
    __________________________________________________ ___________
    Early S Registry #2359
    1970 Porsche 911 Rally 2.4
    2018 Porsche Macan GTS
    Sep 2008
    Rsr engine mount out this week. Mid feb engine skid plates and tank skid pans . Also with Gibs help we have the cibie oscar through horn grill bracket out in approx 3 weeks .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    f/g parts - the start
    First mould set made for the start of a f/g range of goods
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  1. What do you make of my purchase?
    By BrentF in forum General Info
    Last Post: 04-01-2013, 01:15 PM
  2. Can't make it go!!!
    By LDunville in forum Technical Info
    Last Post: 05-16-2012, 05:54 PM
  3. Replies: 18
    Last Post: 08-20-2009, 12:01 PM
  4. Make your car look like a toy
    By classic in forum General Info
    Last Post: 02-02-2009, 10:04 AM
  5. The 68L make over...?
    By bob tilton in forum General Info
    Last Post: 02-24-2006, 07:52 AM
