Results 1 to 2 of 2
Thread: Rear Trailing Arm bushings
    Mar 2012
    Is it a sign these need replacing by an annoying suspension squeak from the back end?
    Can anybody out there give me an estimate of how many hours this job is with a shop that knows how to do it? I read somewhere the engine needs to be dropped (leading to the opportunity to do other things of course ... the old slippery slope.) Thanks in advance,
    Jan 2011
    DFW TX
    Ha! I did this over the weekend on my '74. With the engine already out and the car in the air it only took me about 6 hours. So figure a competent shop could do it in half that... On early cars the engine/ trans does need to come out as the bolts remove to the inside. And then its just a matter of removing the brake calipers, parking brake hardware and probably 1/2 shafts. And putting it all back together and doing an alignment.
    Mine were pretty much disintegrated but there was a little rubber holding things together. I did not notice any degradation in handling or noises. I think its a good "while you're in there" job but I don't know that I would endure the pain just for these bushings alone.
  1. Replies: 11
    Last Post: 05-29-2013, 08:26 AM
  2. WTB: swb rear koni bushings
    By Mdezeeuw in forum For Sale: 911 Parts
    Last Post: 03-19-2013, 11:47 AM
  3. Rear Trailing Arm Bushings - New
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 07-05-2011, 04:00 PM
  4. Rear torsion bar bushings
    By bshea in forum Technical Info
    Last Post: 07-25-2004, 03:18 PM
  5. 67S rear spring plate bushings
    By Fritz A. Ficke in forum Technical Info
    Last Post: 05-28-2004, 04:39 PM
