Thread: Is this a numbers matching car?
    Junior Member
    Jan 2014
    Vancouver
    Is this a numbers matching car? Chassis #: 11830257 Engine #: 3280414. Based on my research it seems this is a USA 1968 911 coupé and the engine is correct for the year...but is it correct for the car? Where can I find that kind of information?
    Thanks!
    Quote Originally Posted by Porscheophile View Post
    Thanks!
    http://www.porsche.com/usa/accessori...fauthenticity/
    Apr 2012
    Simi Valley Ca
    Close
    Chassis # 11830241 has engine #3280376, so it seems that you are close. Get the COA and you will find out if you have the original Trans also.
    Bob B
    Apr 2008
    Virginia's Blue Ridge
    As discussed elsewhere starting at the post below...
    http://www.early911sregistry.org/for...l=1#post703848
    Oct 2008
    Burford, ON, Canada
    Yes the engine # is consistent with the VIN. You can only be certain if you call and ask, or order the COA.
    What more can you tell us about the car?
    Dave
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. How tell if a car is numbers matching?
    By therossatron in forum General Info
    Last Post: 06-16-2013, 04:55 AM
  3. This car was actually a 73E, numbers matching
    By WM711 in forum General Info
    Last Post: 05-30-2010, 11:42 AM
  4. New Guy Matching numbers?
    By wanna911s in forum General Info
    Last Post: 04-21-2008, 10:19 PM
  5. non matching numbers
    By pressure fed in forum Technical Info
    Last Post: 01-08-2007, 07:39 AM
