Results 1 to 9 of 9
Thread: FS: Lemforder ball joints
    I have a pair of new in box Lemfoerder wedge bolt ('72-on) ball joints that I cannot use.
    Will sell pair for $90 or trade for like (new) earlier style, through bolt ('69'71) ball joints.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Feb 2003
    Los Angeles
    Mark,
    I am interested in buying your ball joints. Can you confirm the part number?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Hi Bert,
    These have a part# on the Lemfoerder box, but there are only two versions, Early for '69-'71 with a round notch in the peg for the threaded through bolt, and late for '72-on with a "V" shaped notch in the peg to accept the wedge bolt.
    If you are not sure, look at the bottom of your struts where the ball joint peg inserts. If you have a hex bolt and nut securing the ball joint peg you need the early ones. If you have just a nut on one end of a wedge shaped pin and no hex on the other side of the strut bottom you have the later style.
    I'll look at the boxes when I get home from my office, but make sure by looking at your car....struts get swapped, and the real need will be by what is on your car...nut/bolt or wedge pin/nut.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Feb 2003
    Los Angeles
    Thanks Mark. I'll check on my side tonight.
    Bert Jayasekera
    R Gruppe #167
    Feb 2003
    Corpus Christi, Texas
    Should be 911.341.049.01. That's a good deal btw.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Lemforder box has 901 341 049 01.....not 00 as mentioned. They have the round notch for early ('69-'71) struts. These were purchased form Sunset Porsche a few years ago. One correction...the early struts have just a bolt and washer that threads into threads on the strut...there is no nut. The bolt crosses the notch in the ball joint peg.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Feb 2003
    Los Angeles
    Quote Originally Posted by smedley View Post
    Mark,
    It looks like your part number matches the earlier '69 - '71 style. My struts are the later style dated 1978. I was looking for 911.341.049.01
    I'll have to pass. Thanks for checking.
    Good luck with your sale.
    Bert Jayasekera
    R Gruppe #167
    Oct 2005
    wash dc/ los angeles ca
    Bert I have a new set I'm not using in the later design ,you can have them shipped for $90.00 ,thanks Bert R
    ecrobinson1726@msn.com
    Feb 2003
    Los Angeles
    Hi Bert,
    Thanks for your nice offer. I'll send you an email for details.
    Bert Jayasekera
    R Gruppe #167
  1. FS: SWB Ball Joints Used
    By jhora in forum For Sale: 911 Parts
    Last Post: 11-16-2010, 06:17 PM
  2. FS: SWB Ball Joints
    Last Post: 05-11-2010, 05:38 PM
  3. Ball joints
    By MrJTP2001 in forum Technical Info
    Last Post: 08-11-2009, 01:31 AM
  4. F/S Ball Joints
    By Bobby Smith in forum For Sale: 911 Parts
    Last Post: 08-14-2008, 08:47 AM
  5. 65-68 911 912 ball joints new $195
    By WM711 in forum For Sale: 911 Parts
    Last Post: 10-13-2006, 03:08 PM
