Results 1 to 2 of 2
Thread: Help with switch ID?
    I am eternally confused by the dash switches. Can somebody recall what the switch with two detents out and one to the right is for? I have other switches with one detent out and one to the right for front and rear fogs, but not two. It says 8458 in the bakelite and has the extended back section like the Webasto heater switch.
    Thanks in advance - Matt
    Check out Unobtanium-Inc.com
    New blog posts all the time!
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    matt
    i thought that 2 out and one to the right (twist) is the combination front and rear fogs - first out is front only, maybe second out is front and rear, and twist is rear only or something like that. does it have a part number like 911 613 027 00
    <!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:RelyOnVML/> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]-->
    do you have one?? What do you what for it? i would be a buyer
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  1. FS: NOS 2 stage heater switch-can also use for fog lite switch
    Last Post: 03-08-2013, 09:32 PM
  2. LWB (Rubber Knob) Fog Switch and Driving Light Switch FS
    Last Post: 06-22-2012, 06:37 PM
  3. Replies: 1
    Last Post: 03-09-2012, 07:18 PM
  4. Replies: 0
    Last Post: 09-11-2011, 08:42 PM
  5. Replies: 0
    Last Post: 08-13-2011, 01:19 PM
