Results 1 to 10 of 12
Thread: Dash and pedal box inspiration
    Hi all,
    In building my new race car, I already have a list of things that I am looking to 'better'.
    Two things that that are currently circling in my head are the dash, and the pedal assembly.
    The new car is LHD vs RHD (current race car). There seems to be some consensus that a racing pedal box is better set up in terms of foot ergonomics than the standard set up, and after spending some time in the car playing with seat positions, I am tending to agree.
    So, what are the pedal box options, knowing that there are some expensive ones out there, and are they worth the upgrade?
    Secondly, the dashboard - what are some of the cool things you have seen, given that the dash needs to remain relatively stock but things such as switches for fuel pumps, cut-out switches, lights etc can be added. I have some ideas, but know that the creativity of members of this board is second to none!
    I promise I am not looking to copy, but to gain inspiration!
    Thanks!
    Alex Webster
    1967 911S Sunroof - RHD
    1969 911E - LHD - Historic Racecar
    1975 911 Carrera 2.7 MFI - RHD - Historic Racecar
    My historic racing videos - www.youtube.com/aewebster
    This is what I did, its a OBP pedal box floor mounted with a bias adjuster. I moved it out to the RHS since my RHD car driving position was a bit skewed. The brake is now central. Its all still fllor pivoted so feels right for a 911. I was able to integrate it to the original cluth and throttle cables with some simple engineering. Clutch is a bit heavy since its direct with no helpers and the throttle is sensitive since that too is direct to the carbs.
    Feb 2011
    Northern VA
    Factory style Halda twinmaster/Heuer setupName:  car7.jpg
Size:  124.0 KB. Can't see it here but Chris at Fenn-lane makes a great SC/RS pedal assembly along w converting the ebrake into a fly-off version.
    Mar 2013
    Newport Beach, Orange County, California
    That's a very sweet rally set up - great use of that space in the dash. In my current build I was planning to use the radio delete space for my pair of rally watches, and then convert the glove box to a map/nav station, with pull out red-white light....of course if I had one of these gem Halda's, that would be a centerpiece....awesome patina.
    Kevin "Hangman" Lynch
    1967 912R (project) - color pending
    1968 Bahama Yellow 912
    Follow me on Twitter @LynchGreenDot
    Feb 2011
    Northern VA
    There is a plan to make an exact copy of the factory halda/heuer bracket somewhere on this site.
    Left Hand Drive
    Right Hand Drive
    Pedal spacing and position do not change from stock.
    We are just making an adjustable gas pedal to complement these boxes and to make heel/toe easier.
    The laser cuts are all ready just a small amount of fabrication to finish off.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    very impressive Chris
    Tony
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Sweet Chris, whats the going rate on this ? Do you need a core ? Return time ?
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
    Love that Chris if only it'd been around when I needed one....
    Thanks guys.
    Found some more details on the net, but still keen to see who else has run pedal box conversions and the pros/cons.
    Alex Webster
  1. Clutch pedal interacting with brake pedal
    By POS in forum Technical Info
    Last Post: 11-30-2012, 03:05 PM
  2. FS: Gas Pedal
    Last Post: 05-13-2012, 07:37 AM
  3. 73 RSR Pedal Box
    By mrg3.6 in forum Technical Info
    Last Post: 06-30-2009, 11:14 AM
  4. WTB: 69S gas pedal
    By dhopkins in forum For Sale: 911 Parts
    Last Post: 07-14-2005, 12:07 PM
