Results 1 to 10 of 16
Thread: Engine case 7R in a USA MFI T/E.....what do I have??
    I have a question re when Porsche stopped using 5R cases for USA MFI T/E cars and started using 7R cases?
    I have acquired an engine that definately has a 7R case, both halves, but is from a 73USA T/E chassis 9113110725 so one of the last of the MFI cars
    before the change to CIS injection. Internals are 911/51.
    I have an exact same car in the garage but chassis is an earlier coupe 0350and it definately has all the same markings except its a 5R case.
    I thought all T's had 4R/5R cases even the MFI ones.
    How come this one is a 7R case and yes its original to the car for sure?
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Clyde:
    I think this is pretty good proof that there were few 'absolutes' at the factory in the early 70s. Whenever I hear someone make a definitive statement about what the factory 'always did', a little smile appears on my face knowing that it will most likely prove incorrect. Congrats on finding a 7R case for your 2.5L engine.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Feb 2011
    Surrey, UK
    I am dismantling a 73 2.4T (US) engine for a friend and it also has a 7R case. In the discussion on DDK it seems this is not that uncommon, although the spigot size on these 'T' 7R cases is often 90mm (as in my friend's case ), not the 92mm (?) in the later 2.7 cases. So it seems not all 7R cases were created equal……
    Check which one you have…….
    Mick
    I think the 2.4L spigots are 92 mm and the 2.7L spigots are 97 mm. The 2.5L long stroke ST engine used 86.7 mm P/Cs and they require 94 mm spigots, so that is why only the 2.4L 7R cases work. For a short stroke 2.5L engine, many guys go with a 90 mm P/C set, and the stock 2.7L 7R case works for that application.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Oct 2008
    Burford, ON, Canada
    Any transition cases should be added to this thread; serial, type, revision # from both sides, date codes if found, photo documentation really helps.
    http://www.early911sregistry.org/for...case-Revisions
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Good find Clyde, I also have a 73 T engine s/n 6133470, internals 911/91 with a 7R case small spigot's.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    I too have a 2.4L 7R case 6135015 built for a 911/91 CIS second half 73 car. It will be used with a set of 86.7L ST P/Cs to build a 2.5L long stroke engine. The 86.7 cylinders are the first factory use of Nikasil cylinders for a 911, derived from their successful use on the 917s. I believe all the earlier ST engines used Biral cylinders, including the short stroke 2.5L versions.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Junior Member
    Jan 2014
    Berlin
    Mark,
    I have two Mag 7R cases, both 911/91 (73.5 2.4T CIS small spigot).
    One ist s/n 6133469 (original to my car, looks like a direct neighbour on the production line to yours, Mark!)
    BUT the other one is stamped 6135945...
    What does this mean? It's the high number that makes me wondering... may it be a factory replacement case or something?
    Oct 2008
    Burford, ON, Canada
    911/91 went from 6133001 to 6136092 so 6135945 is okay, just late.
    On the early engines watch for 5R/7R as a transition case; just cause it says 7R on one side...
    Feb 2011
    Surrey, UK
    Quote Originally Posted by letsrollbabe View Post
    Case 6135494 are 90mm.
    Mick
  1. FS: 72S 911/53 engine case
    By vipergruen in forum For Sale: 911 Parts
    Last Post: 02-09-2014, 11:09 AM
  2. 67S NOS 2.0 Engine case
    By Rennman in forum For Sale: 911 Parts
    Last Post: 10-01-2010, 04:44 PM
  3. Replies: 2
    Last Post: 11-20-2008, 11:50 PM
  5. 2.4L S Engine Case: 5R vs 7R?
    By yopurp in forum Technical Info
    Last Post: 06-02-2003, 12:56 PM
