Sierra Madre does not have it listed on their site
and I don't know where else to look.
If anyone knows where I can buy some it would be appreciated.
Its grey in color.
Its grey in color.
Hi, I think Stoddard Porsche Parts sells that. I believe it comes in a roll.
Don't know exactly what you are talking about, but Home Depot sells a heavy putty in the electrical dept. Mfg. by Gardner Bender (P/N DS110) called Duct Seal. Says it seals conduit openings against draft, dust moisture and noise. Used to seal around wires as they pass thru holes in studs. Very heavy bodied. May do the trick here. About $10 for 1 lb. (Google "Gardner Bender DS110")
Bob B
I believe it's Butyl Tape, it is usually available from most hardware or paint stores.
From a vaque recall, the "putty" one wants is non-hydroscopic, that is it doesn't adsorb water. One doesn't want it to absorb and hold water because it would localize moistures and promote rust. I believe it is 3M that makes the correct putty, comes in strips and it is black.
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
70 914-6 #9140431874
73 911s #9113300709
Dumdum, 3M has many shapes and sizes.
Is this what you are looking for?
000-043-129-00-OEM
http://www.pelicanparts.com/catalog/...DYext_pg10.htm
E Sully
1973.5 911T
Sierra Madre does have it here http://www.sierramadrecollection.com..._detail&p=5219 As suggested, many types/manufacturers. I used Terostat and it worked perfectly.
John Forcier
EarlyS #1987
Restoration Saga
You can also use what is commonly referred to as 'plumber's putty'. It's "non-hydroscopic", endothermically pliable, elastomerically enhanced, tri-axially resilient, and all that other stuff. $1.99 at ACE Hardware.
Brian
S Reg #1032
I'm amazed! I just learned how to post a pic.
Thanks guys for all the suggestions regarding
the material needed. I will follow up on all of your leads.
Very much appreciated! Now how do I sign up to become a member?
