Hi
Just mounted the injection pump on our 69s to the block and it seems the pump spacer isnt correct as the pump doesnt sit square, therefore the belt is not aligned correctly. My question is if anyone knows what size this spacer is? You can see it below - it is #24. Any help would be appreciated as i think we will need to find or make this part.
http://www.autoatlanta.com/porsche-p...section=107-20
Scott
