Thread: Need Fitting Removal Help
    Dec 2008
    Woodland Hills, CA
    My scavenge hose from the block to the tank began leaking. I decided to replace the hose and I removed the left side Heat Exchanger to access the hose fitting for removal. The problem is the fitting that's threaded into the block is spinning with the hose fitting. I can't seem to get any type of wrench on it to hold it in place. Between the push rod tube and the block casting, space is limited. Nothing will fit in there to hold the fitting in place while I unscrew the hose fitting. Is there a trick to this? Or a special tool? Thanks in advance
    If I remember right you'll need a thin 32 MM open end to hold the adapter fitting. One solution, if need be, is to remove the "oil return" tube and then install a collaspable one when done with the oil line reinstall. You could also just let the adapter fitting come out with the oil line nut and then when its all out separate them then.
    Dec 2008
    Woodland Hills, CA
    I'm not sure I follow you with removing the oil return tube Ed. The line fitting is a 90 so it wont come off with the fitting. I believe the fitting takes a 26mm open and I think the return line fitting is 32mm.
    Jan 2011
    DFW TX
    You need to remove the oil return tube. Then you will have clearance for a counter hold on the fitting.
    Dec 2008
    Woodland Hills, CA
    I didn't want to remove the oil return tube and end up with one 2 piece setup odd ball non factory in appearance oil return tube setup. I trotted down to Harbor Freight and found this set of metric Chinese wrenches for Fifty bucks.
    I didn't have to grind the wrench to fit. This is a narrow wrench set. The wrench fit like a glove. The fitting is 27mm hex and as Ed stated, the hose fitting is 32mm.
    I found that I couldn't get enough leverage to hold the 27mm wrench, so I slid a pipe over it and they separated easily.
    Well done! Great idea for those that don't have thin wrenches
  1. Argus Fitting
    By Brad Davis in forum Technical Info
    Last Post: 12-15-2016, 04:50 AM
  2. work has started on fitting a AC on my 72T
    By ds58 in forum General Info
    Last Post: 07-20-2012, 10:50 AM
  3. Fitting Ampliluxes
    By geneulm in forum Technical Info
    Last Post: 03-08-2012, 04:28 PM
  4. WTB: Fitting for Oil P sender on RSR
    By Jim Calzia in forum For Sale: 911 Parts
    Last Post: 02-12-2009, 12:56 PM
  5. Can anyone tell me what the heck this fitting is?
    By Eminence Gris in forum Technical Info
    Last Post: 04-22-2008, 08:15 AM
