Page 33 of 90 FirstFirst ... 2331323334354383 ... LastLast
Results 321 to 330 of 895
Thread: Special early 1964 features on 1965 cars
  1. #321
    Hi Richard, the carpet attachment referred to in April 21 1965 letter is the change to leather straps holding the carpet at the top of the trunk/front compartment, to the same attachment method as holding the floor carpets under the dash.
    Good for you - finding this letter and posting it. Each piece of info is very helpful.
    Bob
    Early S Reg #370
  2. #322
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Name:  carpet hooks under hood.jpg
    ref to these hooks. Great letter Richard!! Txs for sharing.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  3. #323
    Junior Member
    Jan 2014
    Switzerland
    On my car (300426) there is no "M8" (what ever that means) on the A-column.
    Does anybody know, when they began with the "M8"-Stamping?
    regards Marcel/turbine930
  4. #324
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by preS View Post
    I owned a 3003xx car at one time with the Delanare A/C system. Question: Do buyers consider this a huge negative even though it was sanctioned by Porsche?
  5. #325
    May 2014
    Netherlands
    When accompanied with such a letter, including the Germenglish, it would be a great ASSET in my view. Top original I'd say. Obviously worth 3-400$ more than without it
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  6. #326
    May 2014
    Netherlands
    Quote Originally Posted by turbine930 View Post
    Good point! My 300700 does not have this. The 301379 I need to check. I also scanned my archives and found all cars that have pictures of this area from up to 1382 not showing it. First car that shows it in my archives is 1620.
    I added this feature in overview below.
    Would be great if you would want to fill in other features for your car as well. Can send you a extract which is easy to fill if you send me yr e-mail by PM. Cheers, Jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  7. #327
    Turbine930:
    the M8 stamped into the hinge panel MAY have changed to the M8 hinge bolts. Some time during the 1965 cars - does anyone have a change date or serial number range for the panel stamping change?
    Did this coincide to when the bolt heads changed from the 13mm (across the flats) to the cheese head bolts at cars 301 554 to 301 555, ( May June 1965) ??
    Bob
    Early S Reg #370
  8. #328
    May 2014
    Netherlands
    Not sure what you mean with cheese head bolts. According to our above overview, the allen bolts were introduced between 1421 and 1620. If that is yr hypothesis, indeed, the 2 changes could very well have been in sync! Where do you derive the very precise 1554-1555 from?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  9. #329
    Yes the parts book is our friend, it uses the term Cheese Head for the allen heads. And they note the serial numbers for the change.... ;-) and with our member derived listing for the 1965/1966 model year change we can see the month of the change. Your listing for appropriate parts by date of application is wonderful - if far exceeds any other method, and it is becoming a companion to the parts book. Good job.
    Bob
    Early S Reg #370
  10. #330
    May 2014
    Netherlands
    The thread is becoming quite long. If you want to find examples of the features, pls use below as reference to find relevant posts.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  1. FS: Very early 4 screw dash top 1964 - 1965
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 12-29-2019, 09:11 AM
  2. Replies: 29
    Last Post: 11-23-2019, 04:41 PM
  3. Replies: 142
    Last Post: 10-22-2016, 05:46 AM
  4. Early heat exchangers 1964/1965
    By Milou in forum Technical Info
    Last Post: 01-14-2014, 10:53 AM
  5. Early 1964 tach and 1965 speedo
    By ixxifan in forum General Info
    Last Post: 06-15-2010, 12:24 PM
