Thread: how to remove stock front sway bar
    Apr 2007
    lake havasu city AZ /auburn wa.
    how do you remove the stock front sway bar on a 67 SWB car other than cutting the end off and pulling it out???
    31 model A coupe
    41 Willys coupe
    70 911 T
    68 911 softie 11880049
    67 912/911 355032
    66 911 303509
    65 911 301275
    Well, you need to have the wheel off for starters, but is the strut still in the way after you take the sway bar lever off? If so the it needs to be disconnected at the top or bottom.
    Apr 2007
    i am removing the whole front suspension and replacing it with green bilstein struts with a weltmister front sway bar
    basically a whole early turbo front end brakes are aluminum s calipers with drilled rotors front and back
    when you take the arms off the square end wont go threw the three bolt plate with out cutting the end off ??
    your car looks alot like mine what year is yours i am upgrading my whole car
    wheel sizes are 7/16 front and 9/16 rear 26mm torsion bars in the rear and 19 front 19mm front sway bar no rear yet but that is in the works
    rs spec 2.7 with S cams built buy Otto's in Venice beach and a 901 ZF gearbox
    the motor has been setting in storage and i haven't run it yet the guy i bought it from said it was nasty fast in a 914 otto's does allot of hot 914's
    31 model A coupe
    41 Willys coupe
    70 911 T
    67 912/911 355032
    66 911 303509
    65 911 301275
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    very often the rubber bearing is seized to the plate(at least on euro cars) so that you have to destroy it(heat).
    Apr 2007
    i think that is what i have to deal with was hoping not to do that it has ben there since 67 i'm sure
    i will give it a try
    31 model A coupe
    41 Willys coupe
    70 911 T
    67 912/911 355032
    66 911 303509
    65 911 301275
    I have a weltmeister 22 and the bushings are sloppy and squeaky so I forgot that the stock ones would be tight. I want to upgrade to a nice set of Taretts.
  1. How to remove glass from 67 front wing vent?
    By 1QuickS in forum Technical Info
    Last Post: 10-01-2023, 10:15 PM
  2. Replies: 3
    Last Post: 10-27-2012, 02:14 PM
  3. Stock 72S TB, sway, shock/struts sizes
    By 911231 in forum General Info
    Last Post: 11-30-2009, 09:16 AM
  4. WTB: Stock Front Sway Bar Parts
    Last Post: 04-20-2007, 12:34 PM
  5. FS: complete, stock 15mm front sway set up
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 11-11-2005, 08:51 AM
