Results 1 to 9 of 9
Thread: WTB: fan pulley
    WTB: fan pulley
    Hello,
    I am looking for a fan pulley fitting a 1970 2.2 engine, see picture. A broken fan wheel including pulley would be fine as well.
    Siegfried
    Hi, we made a batch of brand new pulley centres which rivets to the fan and also the outer pulley. The outer ones are alo available from Porsche. Here is a fan I restored it has our own brand new pulleys (both inner and outer).
    I can check stock if that helps?
    Alan
    Hi Alan,
    sounds great, please check your stock for both parts. I definitely need the pulley center, but could also use a new outer part.
    Thank you!
    Siegfried
    I would be interested in a set as well.
    Thanks in advance,
    Henry
    Here are the outer pulleys we made...
    and the inners
    We are running low and only have a few left so I will look into making some more ASAP
    Alan
    Apr 2004
    Denver, CO
    Good grief those are pretty!
    Quote Originally Posted by Alan.uk View Post
    and the inners
    Alan
    Carl Bauer - OBP
    1979 RoW 911SC
    We are actually making lower pulleys at the moment.
    Need to get the markings finished and then get them plated. Will also make a drilled lighter version.
    Alan
    Apr 2013
    San Diego, CA
    Alan, what is the appropriate way to remove the old rivets holding the hub to the fan, please? Do you just drill them out from the outside (after center-punching the head of the rivet)? Also, what is the size of the shaft of the rivet (so I can size the drillbit)? Thankyou!
  1. Crank pulley
    Last Post: 11-09-2018, 10:06 AM
  2. notches on my pulley
    By lemonlib in forum Technical Info
    Last Post: 10-10-2012, 08:49 AM
  3. WTB: fan pulley wrench...
    By MountainRoads in forum For Sale: 911 Parts
    Last Post: 09-29-2012, 10:21 PM
  4. WTB MFI pulley, tin
    By kllr901 in forum For Sale: 911 Parts
    Last Post: 02-23-2011, 03:15 PM
