Thread: Straightening bent Fuchs
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    Can a slightly bent Fuchs flat 6 be straightened? I bought a cheap one off fleabay and it turned out to be slightly buckled when they were mounting a tire. It is enough to cause a vibration in the car if I fitted it to the car.
    I think in the dim and distant past I had a BBS alloy straightened in the UK, so I believe it should be possible, but is it a) advisable b) cost effective?
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    Lightbulb
    YES !!!! .......
    Try it first, however, if the wheel is really tweaked it can never be balanced out until fixed....if it's fixable...
    Harvey Weidman can give it a try if it's not too bad.........
    Hope this helps
    Hi, we have straightened quite a few Fuchs mostly due to minor impact damage. It is possible but they do need checking and ensuring no cracks or further damage. The number of cracked Fuchs we are finding is pretty alarming.
    Alan
    Mar 2013
    Great, thanks guys. Jim from EASY also recommended Rite Way in Walnut Creek. I'll speak with the wheel seller and see where I go from here.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    May 2005
    Oroville, CA
    I like Rite way and they are good polishers but, PLEASE don't send them a Fuchs for truing...
    We have the specialized tools and equipment designed for repairing Fuchs. If it can be repaired, we can do it.
    Have the seller or you can call me for more info...
    Harvey
  1. Bent Lip behind Gas Tank
    By G69 in forum Technical Info
    Last Post: 09-06-2011, 06:46 PM
  2. WTB bent or damaged 15" fuchs
    By Carrerax in forum For Sale: 911 Parts
    Last Post: 12-13-2009, 09:37 AM
  3. How rules were 'bent' in old days. (pic's)
    By MarkS in forum General Info
    Last Post: 02-14-2007, 03:00 PM
  4. Straightening Rear Deck Grill Slates
    By motortownmatt in forum Technical Info
    Last Post: 11-08-2006, 09:26 AM
  5. All the bent CGT's
    By GreenT in forum General Info
    Last Post: 07-30-2005, 03:10 AM
