Results 1 to 7 of 7
Thread: What is this bracket?
    What is the small bracket used for above the fuel pump?
    It's a 69t
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    It for the CDI if optioned on the T, and standard on the E and S, introduced in MY69
    Tony
    Hi Lee
    I believe all 69T's run a Hardi fuel pump. I found a picture in my files that shows what I believe to be the correct bracket associated with this pump.
    There are 2 69T's at my shop which have the correct brackets. I will look at each car to see if that provision you asked about in your above picture and will get snap shots if needed for reference.
    Regards.
    Peter
    1969 911T Coupe Blood Orange (Vivy)
    Nov 2004
    Gold Coast.
    Peter you are correct that the Hardi pump is mounted on the bracket, which in turn is mounted to the electrical panel via rubber supports.
    I thought the question was with regard to the bracket above the wheel arch. There should be two captive nuts on the arch itself, which is for the CDI unit if optioned on the T and standard on the E & S.
    I can take a photo tomorrow, as my 69T was optioned with the CDI.
    Tony
    Sounds great. One question, would the factory install the bracket even if it wasn't optioned with a CDI.?
    Regards lee
    Nov 2004
    Gold Coast.
    Lee,
    Yes, they used the same panels as the E & S. like most car manufactors they probably didn't descide on the model until the hit the assembly line.
    The main difference between our cars models, are other then the engine, only trim and accessories.
    I'll post a photo after I have woken up.
    Tony
    Nov 2004
    Gold Coast.
    Sorry for the mess!
    Tony
  1. What is this Bracket for? ...... on a 69t LWB
    By leedurrant73 in forum General Info
    Last Post: 04-19-2013, 03:06 PM
  2. Anybody know that this bracket is for?
    By Haasman in forum Technical Info
    Last Post: 02-04-2013, 11:04 PM
  3. WTB: Exhaust bracket
    By oddmund in forum For Sale: 911 Parts
    Last Post: 03-22-2010, 12:44 PM
  4. WTB:Muffler Bracket
    By 911rips in forum For Sale: 911 Parts
    Last Post: 12-02-2009, 02:45 AM
  5. SWB fog light bracket pic
    By jtkkz in forum General Info
    Last Post: 07-14-2009, 08:39 AM
