Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 1971 E clutch kit
    1971 E clutch kit
    Looking to buy a new clutch kit for my 71E but the numbers on the plate that came out of it is no longer available. I can't seem to find an alternative, so can anybody help me out as there seems to be some conflicting kits out there. Thanks.
    Feb 2003
    Corpus Christi, Texas
    what pressure plate was in the car?
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Paragon View Post
    The one that's no longer available...
    He's correct; the original 2.2 plate is technically obsolete. Best suitable replacement is the aluminum 2.4/2.7 sport plate.
    Make sure you replace the pivot ball with an upgraded one while you're in there.
    Is the pressure plate like this one out of my 1970 T
    Name:  911 aluminum pressure plate 007.jpg
    All aluminum except for the fingers. I just rebuilt my trans and plan to reuse this.
    Registry #2507
    1970 911T
    RobR. That's the beast. Exactly the same numbers as my old one. I have heard that the 2.2E can be fitted with a 2.4T/E but I'd like to know from someone that has done this from experience.
    Banned
    Nov 2004
    Scottsdale, AZ
    See post #3.
    2.4/2.7 is available in alum or steel. Would recommend alum for small motor like 2.2.
    Feb 2003
    Los Angeles
    Frank,
    Would the aluminum sport pressure plate put additional stress on the pivot ball? Any increased pedal effort?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Bert View Post
    Frank,
    If anything the steel one would concern me more because of the extra rotating mass. You won't notice any added pedal pressure with the alum 915 plate.
    When Sachs discontinued the 2.2 plates about 10 years ago and we started using the 915 plates we had a few pivot ball failures. Ever since that time we automatically upgraded the ball on every clutch job. No problems since.
    Feb 2003
    Los Angeles
    Thanks Frank.
    Bert Jayasekera
    R Gruppe #167
    Feb 2003
    Los Angeles
    Is it possible to rebuild the factory original aluminum pressure plate? Does anyone know a good rebuilder?
    Bert
    Quote Originally Posted by Rob R View Post
    Bert Jayasekera
    R Gruppe #167
  1. Replies: 8
    Last Post: 01-07-2017, 05:36 AM
  2. Bad Clutch or something else?
    By TFisher in forum Technical Info
    Last Post: 10-18-2010, 08:23 AM
  3. new clutch
    By scargo70 in forum Technical Info
    Last Post: 04-19-2004, 01:16 PM
