Results 1 to 10 of 13
Thread: WTB: 67S rear calipers
    Looking for a set of 67S rear calipers. Thanks!
    Image from Pelican Parts.
    Member #2683
    Dec 2008
    Woodland Hills, CA
    Pretty rare item. Only ran for 2 years...Don't forget that you will need the dog bone mounts as well. Good luck in your search.
    Try this:
    http://www.pmbperformance.com/swb-911-brakes.html
    Thanks! Seems like their site is down at the moment, I'll try later.
    Member #2683
    Aug 2009
    SF Bay Area
    Quote Originally Posted by gsjohnson View Post
    Try this:
    What is a "dogbone" mount? 67S Calipers don't require any adaptors to be used with SWB trailing arms.
    Jim
    Dec 2008
    Woodland Hills, CA
    Jim if he's trying to run vented rotors in the rear he will need the dog bone mounts for the calipers. If he is running solid discs then no dog bones. PBM can also convert solid disc rotors calipers for vented rotors so the dog bone mount isn't necessary.
    Aug 2009
    SF Bay Area
    I still don't know what a "dog bone" is.
    http://www.early911sregistry.org/for...light=dog+bone
    Richard
    Oh Man, Jim
    You don't know what "dog bone mounts" are? FYI, when I took apart the real calipers on my "S", I did not find any "dog bone mounts." Why not? The calipers do have the spacers for the vented discs. What gives?
    Jerry G
    Jan 2007
    North of the GG Bridge
    The dog bones are not the spacers between the caliper halves. They are a spacer that goes between the caliper and the mount on the swing arm. The understanding is this dog bone spacer centers the caliper/pads on the vented rotor.
    This post has a photo and indicated that the dog bone thickness is 3mm.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by 68911+1 View Post
    OK, now I get it. It's one of those parts that would fall on the floor, get swept up and thrown away after cutting up 67 911Ss. Those were the good old days!
    Jim
  1. FS: 930 calipers front & rear, NEW
    By ChristianS in forum For Sale: 911 Parts
    Last Post: 06-30-2013, 03:25 AM
  2. Rear ATE calipers
    By Braukuche in forum For Sale: 911 Parts
    Last Post: 10-13-2012, 08:00 AM
  3. FS: Rear M Calipers (Pair)
    By kentf14 in forum For Sale: 911 Parts
    Last Post: 02-12-2012, 09:30 PM
  4. WTB: Rear M-Calipers
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 03-12-2010, 01:50 PM
  5. 930 calipers on the rear SWB?
    By Burint in forum Technical Info
    Last Post: 05-29-2008, 07:24 AM
