Results 1 to 2 of 2
Thread: Installing new fuel and breather hoses.. help
    Jun 2012
    Overland Park, KS
    I am in the process of taking all the fuel lines out of the car as well as the "breather hoses" in the car. It is a 1972 T When I tried to buy some of the breather hose the vendor said that fuel and breather hose are the same thing.. is that true? Is there someone on the forum that sells the braided fuel line and breather hoses ( oem)? With todays aggressive fuels would you switch the fuel lines over to something more current? TAI
    Registry # 2479
    1970 T Tangerine
    1972 T Albert Blue
    I think Pelikan sells the bulk braided lines. The breather lines for the evap system are mostly fuel resistant PVC. Mcmaster carr sells those.
  1. Replacing Fuel Hoses Running From Tank. 67S
    By bhaubold in forum Technical Info
    Last Post: 09-23-2013, 08:41 PM
  2. replacing fuel lines: hoses and metal lines, 1967
    Last Post: 07-10-2013, 05:28 PM
  3. Replies: 3
    Last Post: 06-08-2011, 08:28 AM
  4. Correct fuel breather venting for a '69
    By endo911rs in forum Technical Info
    Last Post: 07-06-2009, 02:08 PM
  5. Replies: 6
    Last Post: 03-29-2005, 08:04 PM
