Results 1 to 2 of 2
Thread: Gearbox bolt removal.... Or not?
    Mar 2013
    Surrey, UK
    Hi,
    I am rebuilding a 3.0 SC engine for my 1970 T. I recently bought the engine but one of the gearbox studs was left in the engine. The person i bought it off clearly tried to remove it, presumably with mole grips, but failed. I have no reason to remove it and don't think the mild damage to the stud will cause any issues or weakness (the thread is not damaged) but I'd be interested in your opinions... Ok to leave or get it replaced?
    Many thanks
    Paul
    Have you tried the gearbox over that stud to see if its too long ? Sure looks that way to me. So you may need to buy the proper stud removal tool. As to the damage on the stud , file it smooth, won't hurt anything.
  1. 901 Mounting Bolt
    By 50/50 in forum Technical Info
    Last Post: 07-22-2013, 01:02 PM
  2. FS: Bolt in DAS Sport Bar 996
    By Sugarfootfarm in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-13-2013, 07:18 AM
  3. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  4. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  5. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
