Results 1 to 7 of 7
Thread: How to remove the plastic handle from a handbrake assembly?
    Oct 2009
    Indiana
    Anyone know the best way to remove the plastic handle from a handbrake?
    thank you.
    Heat it in boiling water for a couple minutes.
    Slides right off but the handle will be ruined (turns white); I'm assuming you are replacing it.
    Jul 2006
    Corvallis, OR
    Heat gun works also. Just did two of them. Get it hot and spin it off. It won't ruin the handle but I assume you'd be replacing it anyway.
    72S, 72T now ST
    Oct 2009
    Indiana
    heat gun ... i would never have thought of that. Sheer genius.
    Heat gun and a piece of wood with a U shaped slot made with hole the same ID of the steel. Heat it up put the wood behind the plastic handle and tap the wood with a hammer. Piece will come off undamaged. Are the new ones still stipple finished or are they polished smooth again?
    The new ones from Porsche are stipple finished so if you want original look after the one being removed.
    Hth
    Alan
    Jan 2011
    DFW TX
    Be careful reinstalling... I got mine off nicely and then it split when I put it back together. Too much paint thickness I think. So now I have a new stippled one which doesn't look or feel right.
  1. 66-77 new leather handbrake boot/handle combo
    By Vwbobd in forum For Sale: 911 Parts
    Last Post: 11-25-2010, 06:26 AM
  2. Nicely restored handbrake assembly
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 12-10-2009, 07:19 PM
  3. Removing handbrake assembly
    Last Post: 02-06-2007, 08:23 AM
  4. Handbrake Assembly w/ two small levers
    Last Post: 06-23-2006, 11:52 AM
  5. How to remove headlight assembly...
    By VinnyC in forum Technical Info
    Last Post: 04-11-2006, 10:36 AM
