Results 1 to 10 of 10
Thread: Cleaning Heat Exchangers
    Oct 2012
    ON
    This may be a dumb question but I have no previous experience with bead blasting. Is it OK to bead blast the heat exchangers to clean them prior to painting? I can just see all those beads ending up inside the exchangers and hope they can be removed. Should I be using a particular medium? So before I do something possibly stupid I thought I would ask the question.
    Also does anyone know what temp the heat exchangers get up to?
    Thanks for your invaluable help.
    Member #2666
    Oct 2012
    ON
    So I take it no one has bead or sand blasted their heat exchangers?
    Member #2666
    We bead blast them all the time, just use an air nozzle to blow out the beads. Occasionally when diagnosing engine problems I'll use an infra-red gun to measure pipe temps, I'll see up to 350 (F) or so at idle.
    Oct 2012
    ON
    Thanks Ed, really appreciate the response.
    I was talking to a gentleman that has a large powder coat operation and he said they have finishes (powder coat) now that are good up to 1000F. If that is the case would it be possible to powder coat the heat exchangers? I had always thought they would get too hot since regular powder coating uses curing temps around 400F. Has anyone done this or heard of it?
    Member #2666
    I have never powder coated heat exchangers, just used some type of hi-temp paint suitable for exhausts. It seems I may have heard that powder coated exhaust may emit some fumes you don't want to breathe, like when the heater is on! Any one else know more about this?
    Jan 2011
    DFW TX
    I've always used VHT on manifolds and heat exchangers with good results.
    Dec 2008
    Woodland Hills, CA
    Ceramic coating is the way to go...and it lasts...A little pricey though.
    Senior Member CidTito's Avatar
    Jan 2008
    Emeryville, California
    I've never done this.. nor have I thought of anything like it. My guess is it would really get hard to get in those seam grooves, but I assume if you work at it long enough, you could get them spanking cleaned up. I guess you can duct tape any holes in the heat exchangers before putting them in bead blaster.
    E911SR #2107
    69 911T/S SWT 3.2L
    RG #384
    Oct 2012
    ON
    Yes, they plug all the main holes but I know there are still gaps. Being able to blow out the glass beads as Ed mentioned makes sense. I'll just use the VHT paint I used on the muffler to finish it off. Maybe powder coat in the distant future if it turns out to be a viable and safe option.
    Member #2666
    Would it be a good idea to run the heat exchangers through a parts washer first to get any residue (oil, carbon, etc) out of them while they are off the car?
    Jake
    Early 911S Registry Member #2799
    1973 911S - "Tangerine Tornado" - Two Time SCCA Solo II National Champion (1976 and 1981)
    1967 Corvette Roadster (Black/Black/Black) 4-speed
  1. Cleaning SSI exchangers
    By Kris Clewell in forum Technical Info
    Last Post: 12-12-2013, 06:19 PM
  2. SSI Heat Exchangers
    By Aircool in forum Technical Info
    Last Post: 05-10-2013, 01:33 PM
  3. WTB - set of heat exchangers for 69T 911
    By beaker in forum For Sale: 911 Parts
    Last Post: 08-22-2009, 07:48 AM
  4. WTB - Heat Exchangers - 69 E
    By Steve G in forum For Sale: 911 Parts
    Last Post: 12-07-2005, 07:28 AM
  5. SSI heat exchangers
    By Ed B in forum General Info
    Last Post: 09-05-2005, 06:33 AM
