Results 1 to 9 of 9
Thread: 911 S suspension
    Junior Member
    Feb 2014
    Virginia
    911 S suspension
    Hello everyone!
    I just purchased a '73 911S Targa. It s a good driver.
    The former owner has lowered the car and installed a track worthy suspension. Looks like 1-1/2 to 2 inches I reckon.
    Being middle aged and having titanium parts in my spine nowadays (from, ironically, racing) I cannot tolerate too stiff a ride.
    What parts do you imagine I need to bring "Louise" back to stock, factory specs? And, what shocks should I install?
    The wheels and tires are the original specs.
    Much thanks.
    JWW
    PS. "Louise" Johanna Kaes was SR. Dr. Ferdinand Porsche's wife as you may know.
    Aug 2009
    SF Bay Area
    Your car came with Koni Struts and aluminum "S" calipers. It would help to see pictures of your struts and the spindles to determine if the PO moved the spindles on the struts. The PO could have used many different methods to slam the car on the ground, some of which will not be easy or cheap to rectify. The attached pictures are what your suspension should look like.
    Jim
    Some questions I would be asking...
    1) Does the car have the original torsion bars or some stiffer versions?
    2) Status of the shocks (see Jim's comments to start).
    3) Does it have original or adjustable spring plates?
    4) Are the banana arms original or upgraded? (I have aluminum rear trailing arms on mine...great for negative camber...and the originals in storage).
    5) Are the drop links stock or upgraded?
    I would think that the biggest affect on ride comfort will come from the torsion bars. That being said, all of the above components play into ride height. You can do no better than Jim B. for help with the details!
    Have fun and let's see some pictures!!
    Peter Kane
    '72 911S Targa
    Feb 2003
    Corpus Christi, Texas
    Most track cars will have harder (poly-graphite or delrin) bushings installed on the spring plates, control arms and perhaps even the trailing arms. If that's the case on your car, you will probably want to go back to something similar to the factory rubber.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Oct 2010
    Florida
    I find the sway bars make a big difference. They're also easy to change - or undo. I normally use the stock S bars front and rear. Also stock torsion bars. That give me a great street ride. It also gives me a lot of body roll at the track. I have some huge anti-roll bars for the track but they make the car really rough on the street.
    You might try unhooking one end of your bars and see what happens. It's easy enough to do.
    Richard Newton
    Car Tech Stuff
    On Targas you can not go as stiff as a coupe. I too was looking for a sporty but not harsh street ride.
    21 front torsion bars, (you can stick with original 19's) 25 rear
    I replaced all bushings with elephant rubber replacements. Original roll bars front and rear.
    Koni adjustable gas front and rear shocks, original spindle height. 205/50/16. 225/55/16 fr and r tires.
    Jim, I think the factory only used Konis on S Targas as an option, mine came with Boge. The S coupes all came with Koni.
    Junior Member
    Feb 2014
    Virginia
    Thanks for the excellent advice.
    Ill have the shop raise the car back to USA ride height and put the original sway bar back on.
    Im not expert enough to tell if the other bits and pieces were changed.
    As for shocks, Ill put the Konis on.
    JWW
    Feb 2003
    When they raise the ride height have them check the size of the front torsion bars. If the fronts are larger than stock safe to say the rears are larger as well. I'm betting someone on the list would be willing to swap you stock parts for your aftermarket pieces. I'd suggest going with the standard hydraulic Koni's.
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    Aug 2009
    SF Bay Area
    I would raise the car to European height. The US spec was too high and was done just to satisfy the headlight height from the ground. Almost all 911s got lowered to their intended height after arriving in the US.
    Ciao
    Jim
  1. Need some help with SWB suspension. . .
    By 304065 in forum Technical Info
    Last Post: 12-31-2017, 03:59 PM
  2. Suspension
    By MrJTP2001 in forum Technical Info
    Last Post: 06-16-2009, 06:34 PM
  3. 67 suspension pan fix
    By CarmelSkip in forum For Sale: 911 Parts
    Last Post: 02-15-2009, 05:56 AM
  4. 911 SC/RS suspension
    By Porsche-RSR in forum Technical Info
    Last Post: 01-08-2009, 01:41 PM
  5. SWB suspension set up
    By Alex Webster in forum Technical Info
    Last Post: 03-14-2007, 05:35 AM
