Results 1 to 10 of 14
Thread: Cleaning spark plugs
    Senior Member Bavaria911's Avatar
    Dec 2012
    Fort Meade, MD
    I removed my sooty spark plugs from my motor and will buy newer plugs once I determine which type is best for a street used 2.4S with MFI, but until then I'd like to clean them - reinstall to drive the car to the repair shop . The MFI pump Is running too rich.
    Can I soak the plugs in carb cleaner for a few hours?
    Vr,
    Scott
    Jan 2011
    Sunny Southern France
    Carefully wire brush them.
    Set the gap while you're at it, if you know the original gap of course...
    Olivier
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Media blaster works great, if you have one
    Tony
    old softie67S
    Feb 2007
    Sanibel Fl
    I have had one of these for years
    http://www.amazon.com/Cleaner-Pneuma.../dp/B006SJLR22
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Burn them! Oxy Acetylene works fine, and maybe LPG
    70 911 ST
    92 911 Carerra rs n/gt
    85 911 Carerra 3,2l
    Rather than take the risk of having fine blasting residue in the cylinder, just throw them away and buy new.
    Dec 2012
    Fort Meade, MD
    Thanks guys.
    So I take it that soaking a plugs in carb cleaner will not damage them. I used a toothbrush and they came out looking okay. I checked the gap and all are at 22-24 (fit my smallest gap tool wire loop).
    I'd like to think the plugs are still useable with only 2600 miles on them, just to drive it to the shop. I'll ask to have them replaced.
    Vr,
    Scott
    sure, go for it
    I would dial in the MFI and get new ones - if you need them to get to the shop - use a wire brush and then blow them out with air compressor
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Throw in garbage and buy NGK BP7ES for $2.19 each. Install and enjoy. When those get dirty, throw THEM in the garbage and repeat.
  1. 2.2 spark plugs
    By TZombek in forum Technical Info
    Last Post: 11-27-2012, 11:43 AM
  2. 73 S spark plugs
    By philip guiral in forum Technical Info
    Last Post: 03-03-2010, 07:03 AM
  3. Spark plugs---which?
    By Zeke in forum Technical Info
    Last Post: 02-16-2004, 09:18 PM
  4. Spark plugs for '73 S
    By jayzoll in forum Technical Info
    Last Post: 12-22-2003, 06:58 AM
  5. '73 S spark plugs
    By Plays with Cars in forum Technical Info
    Last Post: 05-22-2002, 12:52 PM
