Thread: 930 tensioner bleeding?
    Nov 2006
    S. F. Bay Area
    New 930 (NON-pressure fed) tensioners: Before I install, is bleeding required? I've found answers both ways. Thanks
    Brian
    S Reg #1032
    Absolutely, with 60W oil.
    Yes. The best way to accomplish this is to attempt to compress the tensioner using a large pair of rusty channel lock pliers borrowed from your neighbor. Usually this results in the pliers slipping off the rounded base of the tensioner, pinching your skin in the pliers, drawing blood. You may have to repeat this exercise two or three times before you give up, compress the tensioners in a vise with something to push the piston below the level required to insert the pin, insert the pin, install the tensioner, then use an oil can to fill the tensioner cup with oil, pull the pin, torque the prevailing torque lock nut, witness mark the nut and then pour yourself a Jaegermeister to blunt the pain of the bleeding exercise.
    Nov 2006
    S. F. Bay Area
    So..I'll take that as a "not required"… too funny!!!
    Brian
    S Reg #1032
    Nov 2006
    S. F. Bay Area
    I do, however, fancy the Jaegermeister!!!
    Brian
    S Reg #1032
    May 2011
    Chelsea, Québec
    Very funny... I missed the point when I first read it, but now: ROFL
    Member #1616
  1. is the "container for bleeding" serviceable
    Last Post: 10-20-2018, 04:30 AM
  2. Bleeding Brakes
    By Bert in forum Technical Info
    Last Post: 09-13-2016, 03:17 AM
  3. '68 911 Brake Caliper Bleeding Nut Position
    By 68911USA in forum Technical Info
    Last Post: 04-04-2009, 07:09 AM
  4. Brake Bleeding snafu - need help!
    By wolfturbo in forum Technical Info
    Last Post: 07-09-2003, 11:37 AM
  5. Brake Bleeding snafu - need help!
    By wolfturbo in forum General Info
    Last Post: 07-06-2003, 03:14 PM
