Results 1 to 9 of 9
Thread: How do I remove my distributor?
    Mar 2013
    Surrey, UK
    I'm currently rebuilding a 79 SC engine to put into my 70T. I've following the Engine Rebuild book and have got as far as trying to remove the distributor. The engine is at TDC and I have removed the nut that holds it in place. The book says 'simply slide the distributor out', but it won't budge. It turns freely within the adjustment that is allowed when the nut is loose, but I have no idea how to get the thing out as it just won't simply slide out. Is there some magic trick that i'm missing?
    thanks
    Paul
    Senior Member Curt Hammill's Avatar
    Aug 2011
    Cupertino Calif
    Sounds like you removed the nut on the distributor to the bracket, try removing the nut on the distributor bracket to the engine.
    Which engine are trying to remove the distributor from? If 70 T, then as Curt said you may be removing the wrong nut (bolt) If the SC engine then there is only one nut to remove. It is not unusual to have to pry the distributor up out of the hole since it likely hasn't been out for a while.
    Mar 2013
    Surrey, UK
    Its the SC distributor i'm trying to remove. In fact i can't get the rotor arm off. Perhaps the distributor really will slip off if i can get that off, but it won't budge!
    Here's a photo. There's only 1 bolt that holds it on.
    Aug 2011
    New York
    Just pull up as you twist. The only thing keeping it in is the rubber seal.
    E Sully
    1973.5 911T
    Mar 2013
    Surrey, UK
    Many thanks. With a bit of gentle leverage it finally came out.
    Aug 2005
    VA
    Yea, its a PITA to get out. Leverage and patients is the tcket.
    Chris
    73 911 E
    Aug 2009
    SF Bay Area
    Quote Originally Posted by PMNorris View Post
    Now that you have been successful with your distributor removal, the rest of the rebuild will be a snap!
    Jim
    Mar 2013
    Surrey, UK
    I hope so. Just ordered USD 2.5k of new parts for it. Mainly clutch and flywheel as it didn't come with them. I need to buy carbs and new induction then i can nail it back together. Meanwhile, most of the parts i have removed are being cleaned locally. Prices in Poland for reconditioning etc are around 50% of what you would pay elsewhere in Europe.
  1. How do you remove the gauges on a '69 911?
    By wolfturbo in forum Technical Info
    Last Post: 12-02-2021, 09:39 AM
  2. How to remove dash pad on 73
    By Mark Wilson in forum Technical Info
    Last Post: 08-17-2013, 04:27 PM
  3. 71 911e a/c keep or remove
    By mishwa in forum General Info
    Last Post: 07-27-2013, 03:08 AM
  4. Replies: 1
    Last Post: 08-03-2011, 10:40 AM
  5. How do I remove lens from H1?
    By Alan B in forum Technical Info
    Last Post: 10-03-2007, 08:57 AM
