Results 1 to 7 of 7
Thread: Blaupunkt Radio Hookup?
    Oct 2012
    ON
    I did a search but couldn't find anything to answer my questions. Below is a picture of the back of my radio which I would like to install. I've labelled each wire which may or may not be correct. I can see just plugging in the antenna but don't know what to do with the speakers. I have two door speakers and the dash speaker. Is the speaker connection too old, do I need something else? Pictures and a description would be great if anyone has some. Where does the ground go, which I assume is missing? Thanks.
    Member #2666
    Oct 2010
    South Carolina
    You've got it. the yellow wire is the power and should have an inline fuse. There is a little selector tab for 12V/6V. The triangular plug is for speakers. The pigtail on your speakers should have a two prong connector. You plug it into the bottom of the triangle and the top left or right socket depending if you have 1 or 2 speakers connected. I have a diagram I can send you if you give me you email.
    Bryan
    Oct 2012
    ON
    Thanks Bryan, sent you a PM with my e-mail. Which sockets do you use if you have 3 speakers? Where do you get pigtails for the speakers as I just have exposed wire?
    Member #2666
    Oct 2010
    South Carolina
Size:  33.3 KBName:  scan0003.jpg
Size:  53.1 KBName:  scan0002.jpg
    Oct 2012
    ON
    Thank you Bryan and mcampuzano. Found a 2 prong plug on another radio I have so will try wiring it up and see what I get. I assume grounding is not necessary if radio is in contact with the cars body.
    Member #2666
    Apr 2012
    Simi Valley Ca
    I would add a ground wire just to be safe. Use one of the small screws on the chassis.
    Bob B
  1. WTB: Radio DIN mounting plate (for a radio like a Blaupunkt)
    By Haasman in forum For Sale: 911 Parts
    Last Post: 02-26-2013, 03:00 PM
  2. FS: NOS 72/73 radio plate and bezel for a Blaupunkt Frankfurt radio
    By Jim Breazeale in forum For Sale: 911 Parts
    Last Post: 02-02-2013, 01:09 PM
  3. Wtb blaupunkt radio for 73 911
    By denson in forum For Sale: 911 Parts
    Last Post: 05-24-2009, 04:57 PM
