Results 1 to 10 of 15
Thread: Original underbody markings on a 1965 car
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    I am in the process of restoring my 1965 912.
    This was built in August of 1965 at the Porsche factory.
    I have recently had the body shell chemically stripped, and today was its first time back on the rotisserie.
    When I turned it over to do some work on the sills I was able to have a good look at the bottom of the car.
    Because the stripping process only removes surface coatings an not rust or corrosion some original factory (or steel company) markings are visible repeating twice down through the centre of the external floor.
    I have done my best to photograph it, for no other reason than that it seems interesting.
    I had almost started to clean it down with Picklex 20 and a test on the markings showed that this will remove them.
    It shows a company name and the date 3 5 65
    Apr 2010
    Adelaide Australia
    A couple more
Size:  90.8 KBName:  DSC_0650.jpg
Size:  93.5 KBName:  DSC_0652.jpg
    On this last pic you can see a couple of small sections of the floor which have already been cleaned with picklex
    I found the same OMH markings under the green primer on a 356 nose panel I installed.
    Port Macquarie, Australia
    Nice work Chris. This would have to be a very, very early RHD chassis?
    John Forcier
    EarlyS #1987
    Restoration Saga
    Apr 2010
    Adelaide Australia
    Many years have passed and the car is now a finished product, I learned a lot along the way, as you do.
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    Amazing car Chris, the car has also grown two more cylinders in the last few years
    May 2011
    Chelsea, Québec
    Awesome work and outcome! Thanks for posting...
    Member #1616
    WOW Chris... Outstanding !!!
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    What's the story on the left gauge........ on the 912?.....( Multi gauge ).....cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Apr 2010
    Adelaide Australia
    Yes, multi. Made specially by North Hollywood, you have a good eye to have noticed that from the photo.
  1. Original Head Markings on Fender Screws ? ? ?
    By bobmagyar in forum Technical Info
    Last Post: 11-14-2018, 04:26 AM
  2. FS: near mint original patina hood badge with correct markings
    Last Post: 03-01-2013, 08:19 PM
  3. Replies: 2
    Last Post: 12-10-2010, 12:33 PM
  4. Replies: 11
    Last Post: 01-16-2009, 06:45 AM
  5. Underbody help
    By 911s911rs in forum Technical Info
    Last Post: 08-20-2004, 07:16 PM
