Thread: WTB: 901 gearbox drive flanges
    Mar 2012
    South Africa
    Hello
    I am looking for a pair of 902/0 gearbox drive flanges.
    The first cv joint type flange for 1967 to 1969
    they fit the smaller diameter cv joint
    2 of early 911/912 drive flanges
    diameter where seal runs 45mm
    shaft diameter 34mm
    diameter of splines 33.8mm
    number of splines 18
    1 inch is 25,4mm for our American Friends
    thanks greg
    Greg B
    South Africa
    67 911S coupe
    68 911 coupe
    71 2.2t targa
    recreations
    bailey 917LM
    73 RSR
    Jan 2014
    Adelaide South Australia
    PM sent Regards Peter
    Aug 2009
    SF Bay Area
    Quote Originally Posted by gregary View Post
    Hello
    shaft diameter 34mm
    thanks greg
    Make sure that the seller provides you with the bolts, washers, grease caps and clips. Without all of that stuff, the flanges are unusable.
    Jim
    Greg...did you ever find the early flanges.....I have a pair if still need a set....Regards....John
  1. WTB: löbro drive shaft flanges
    By moito in forum For Sale: 911 Parts
    Last Post: 10-16-2013, 08:28 AM
  2. Nadella drive flanges
    Last Post: 03-14-2012, 06:03 PM
  3. WTB 901/914 OEM LSD with Flanges
    By Erik@Carquip in forum For Sale: 911 Parts
    Last Post: 10-18-2010, 01:13 PM
  4. LSD and Flanges
    Last Post: 03-25-2009, 11:53 AM
  5. WTB Nadella axle drive flanges
    Last Post: 12-29-2005, 05:11 AM
