Results 1 to 7 of 7
Thread: Are these dimensions correct for a SWB car?
    Aug 2013
    Westlake Village, Ca.
    If not, does anyone have them? Thanks
    Scott
    303581
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    swb and lwb(not talking about the rs) have the same dimensions...except for the front axle aux. suport mounts and the trans. mounts... those points are something like 3mm raised on the swb...but in reality this difference you can not measure with a measurement tape...you have to put the car on a jig to see this.
    the rear engine mounts have a quite big tolerance in hight and lenght (+/-4mm !!!!!) so it is not really possible to do a meaningfull measurement... the 752mm width seem correct if i remember right.
    not so sure if all swb have this measurement holes in the floor pan...so most of the data shown on this illustration are useless in this case.
    what you need this data for? rust repair...damage repair? both?
    Aug 2013
    Replacing the front suspension pan. I bought this from RD and was checking the dimensions. According the the specs in my first post, this dimension should be 22 1/4" from the center of hole to center of hole. I am measuring 21 3/4" between holes?
    Name:  front suspension pan.JPG
    Scott
    303581
    I've used several RD pans, never checked that dimension though, however that won't be a problem, their holes line up with the factory jig copy from Stoddard. More important is to be sure you use the reinforcements that weld in from the top before you weld on the tank support. Otherwise you could rip out those weldments making that slight discrepancy immaterial.
    Aug 2013
    Thanks Ed, yes I have the reinforcements.
    Scott
    303581
    May 2009
    Wellington, New Zealand
    If you flip the panel over and measure again is it different? The welded in lugs are on an angle.
    If you imagine it looks like this //.......\\
    Regards,
    Reuben
    Aug 2013
    You are correct about the angle of the threaded holes. The dimension is still 1/4" off from the specs on the drawing when I measured from the other side.
    Scott
    303581
  1. MFI injector dimensions
    By jpnovak in forum Technical Info
    Last Post: 11-22-2011, 06:58 PM
  2. LWB dimensions needed
    By jhelgesen in forum Technical Info
    Last Post: 08-31-2011, 04:31 AM
  3. Engine case dimensions ?
    By ydderf911 in forum Technical Info
    Last Post: 08-30-2011, 12:50 PM
  4. Battery Box Dimensions
    By joetiii in forum Technical Info
    Last Post: 04-11-2010, 06:36 AM
  5. 901 flywheel dimensions
    By tomkirkcis in forum Technical Info
    Last Post: 11-26-2009, 10:46 AM
