Thread: Pertronix Igniter I or Ignitor II
    I called Pertronix to see about Igniter I and Igniter II for my 73S dist. # 0231 184 003. The Igniter I part # 1867A and Igniter II # 91867A. I went to Pelican to order and the listing for the Igniter II is for 1973 1/2. Will this fit? It appears some advantage to the II.
    I just got my answer from Glenn at Pelican. Ignitor II does fit.
    Dec 2009
    Copenhagen, Denmark
    Ok Justin Bieber.
    James Hurst #1638
    R Gruppe #514
  1. Which Pertronix Ignitor
    By Irish911 in forum Technical Info
    Last Post: 12-09-2013, 05:13 PM
  2. Replies: 0
    Last Post: 11-15-2010, 07:53 AM
  3. pertronix ignitor
    By KarlHash in forum Technical Info
    Last Post: 08-07-2009, 04:05 AM
  4. Ignitor reference numbers
    By manu72S in forum Technical Info
    Last Post: 03-05-2007, 09:18 AM
  5. Coil wires / ignitor
    By philip guiral in forum Technical Info
    Last Post: 03-20-2004, 01:44 PM
