Results 1 to 10 of 11
Thread: 60 weight oil for tensioners
    Jan 2013
    Montreal
    Well I dropped by my auto parts store looking for 60 weight oil to rebuild my tensioners and couldn't find any. Any ideas on which brand to use and where to get it.
    1968 911T R.O.W. / 68S engine.
    60 weight not as important as having Jaegermeister
    see this thread
    http://www.early911sregistry.org/for...571#post714571
    Quote Originally Posted by Norm01 View Post
    Try motorcycle shops.
    Jan 2013
    Montreal
    Thanks Ed, I think you're right since most of my online searches kept leading to motorcycle oil. I'll check it out this weekend.
    My $0.02 worth. There is a more modern way, use a good synthetic motor oil. Mobil-1 is our house brand, I use the 10-40 but one can also use the 15-50. I would venture to say the tensioners will react a lot quicker without the molasses. They will certainly will run cooler, not stress the O-rings and seals as much and lubricate them-self's internally much better. I prefer the 930 isolated tensioners over the Carrera pressure fed and have rebuilt more that I can remember without a failure to date. However a failsafe / safety kit is highly recommended no matter what you choose.
    Bernd Buschen
    R Gruppe # 357
    71' 914-6 Original Owner
    70' 914-6 GT Stoddard Built
    69' 911E Scott's car
    70' 914-6 Sold
    Jan 2013
    Montreal
    Quote Originally Posted by Bernie B View Post
    I've got lots of Mobil 1 0W40, would that do? and I do have the collars on them.
    Ed has a lot of experience. I'd follow his advice.
    Jan 2013
    Montreal
    Ok Ed, what do you think. Would you try Mobil 1 10W40 or 0W40
    Jan 2011
    DFW TX
    A hydraulic damping system works on the basis of orifice size and oil viscosity. Changing a system designed for straight 60 weight oil to a low base viscosity multi grade does not compute for me. The damping characteristics will change.
    Actually that was already tried when the tensioners were new, so in the seventies when tensioner failure was not uncommon we decided to try a higher viscosity oil in the hopes that it wouldn't seep past the seals as easily. I don't know that we ever saw a failure with those tensioners. Then over the years Porsche kept improving the tensioner and the idler sprocket support arms, and then the aftermarket came up with the guards as a device to prevent total collapse. With all of that I would say that a tensioner failure is very rare now. So to answer your question I've already been there when thinner oil was used and prefer not to use it, but you should do what suits you.
  1. 911 Vehicle Weight
    By LongRanger in forum Technical Info
    Last Post: 06-09-2023, 05:17 AM
  2. anyone know the approx weight of a 2.4?
    By EARLY911ZOO in forum Technical Info
    Last Post: 04-29-2013, 08:07 PM
  3. Weight of cases
    By Dave Mitchell in forum Technical Info
    Last Post: 11-30-2009, 05:32 PM
  4. 911 muffler weight?
    By demo in forum General Info
    Last Post: 11-29-2006, 03:16 PM
  5. Weight!
    By 69Sman in forum Technical Info
    Last Post: 01-31-2004, 07:55 PM
