Results 1 to 10 of 10
Thread: Curious exhaust on early 911
    Senior Member Christian Guthrie's Avatar
    Jun 2011
    Arizona
    Anbody know anything about the vertical pipe extending out of the right hand lower valance (directly above Butzi's head)? Looked at this picture a million times and just noticed it. Early gas heater located in the engine bay? Overboard drain hose? Very interesting.
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    The whole picture is full of little surprises... the left rear tire seems to have been badly damaged, and I didn't see the mechanic under the car until I looked at the photo for several minutes. The car doesn't have an engine bonnet and the twin exit pipes on the exhaust appear to have a smaller than normal diameter.
    -That drain pipe could be for oil overflow... just a guess.
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    One piece rear valance? No cut outs in front valance for fog lights
    Nov 2003
    Santa Monica CA
    these are prototype 911's. --yes the rear valance was one piece from corner to corner. Could the drain above Butzi's head be the water drain for the taillight lens box? We all have the little ones there now. Looks too big though. Could also be the exhaust for the Gasoline heater. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Jul 2006
    Switzerland
    Quote Originally Posted by raspy2point2 View Post
    +1 .
    Registry member No.773
    Road draft tube crankcase breather???? This was an era before that stuff was vented back into the intake even though they had already started doing that on the 356 C models.
    Mar 2006
    Louisville KY
    I'm curious to know if it had a 356C transmission in it the way those rear wheels are hanging down!
    Tony Proasi
    52 split window coupe
    Jul 2006
    Switzerland
    Quote Originally Posted by 911quest View Post
    One had 356B rear axle and S90 engine (13321), Transmissions got several times exchanged and varied between 4 and 5 speed w different gear ratio including similar to 356SC's, one as early as 1964 with automatic transmission (13325), one as early as 1965 w 170hp S engine (13324). Also, some were 902 4cyl/356 engine prototypes.
    Exhaust configurations varied too
    The T7 4seater (1959/1961) Type 754 had another rear configuration, engine air was from underneath numberplate and sideways.
    Curious Exhaust on Early 911
    Here's another image of a 911 with a "Curious Exhaust", perhaps another picture of the same car.
    CW
    Jul 2006
    Switzerland
    Charlie, above car had different engine louvres…these are the very early "vertical style" engine grills, approx 1962/63.
    same car here:
    another version but still not 901 size
  1. Early slant exhaust tip
    By 356rider in forum Technical Info
    Last Post: 01-13-2014, 06:02 PM
  2. Hood Latch Number - Curious Question
    By Peanut in forum Technical Info
    Last Post: 10-20-2012, 01:52 PM
  3. Curious. Why delete sale price after item sold?
    Last Post: 08-06-2011, 05:46 PM
  4. curious about a 66'
    By vintage83 in forum General Info
    Last Post: 08-15-2008, 09:12 AM
