Results 1 to 10 of 10
Thread: SF Bay Area Powder Coating Recommendation
    Oct 2010
    San Francisco
    Can anyone recommend a source in the SF Bay Area for powder coating a '67S engine air cleaner assembly and other engine sheet metal? This sheet metal was powder coated over thirty years ago but is gloss black and I wanted to get an original looking finish. Thanks.
    Bill
    Aug 2009
    SF Bay Area
    Quote Originally Posted by TeeItUp View Post
    Bill
    If it was done in the Bay Area 30 years ago, it was probably done at Poly Engineering in Richmond. You can still take it there and have it done in any color you want.
    Jim
    Nov 2006
    S. F. Bay Area
    I've had great results with West Coast Powder Coating in Concord. See Kyle.
    Brian
    S Reg #1032
    Sep 2006
    San Francisco
    I had mine done at West Coast Powder Coating in South San Francisco. The owner AJ owns several 911s (including an RS) and a Speedster so he gets our cars. I went with 60% gloss for the tin and it's a good match for the original paint.
    I see both I and the poster before recommended the same name but in different cities. Not sure if they are affiliated.
    Jeff Jensen
    Feb 2010
    San Francisco, CA
    +1 to Jeff's comments about AJ in SSF. He's a good guy that knows our cars and is an enthusiast himself. Cool guy to chat with.
    165 Mitchell Ave, S San Francisco, CA
    (650) 871-0400
    E911SR & RGRUPPE
    '73 S Coupe #306
    Feb 2010
    San Francisco, CA
    But.... if you're looking for an original finish on your '67S air cleaner housing you may want to have it painted rather than powder coated.
    Cheers
    E911SR & RGRUPPE
    '73 S Coupe #306
    Oct 2010
    San Francisco
    Thanks to all for the responses. Jeff's guy in SSF is close to me so I think I'll pay him a visit. Can old powder coating be painted over or does it need to be stripped? If you paint the air cleaner housing would you also paint the other engine sheet metal?
    Bill
    Die schönste Rennstrecke der Welt. Nordschleife's Avatar
    Dec 2006
    What would be the correct finish for the air cleaner housing? Is 30% gloss black approximately correct? I know it's not full gloss black but...
    Early 911S Registry #1246
    1968 Porsche 911 Cotswold Blue/Schwartz #118 35153
    1962 Marcos G.T. 1000 Gullwing historic race car - now sold and racing in FIA events in Sweden
    "Pro Patria Vigilans"
    Aug 2009
    SF Bay Area
    I would have no problem using AJ, in fact, I should have mentioned him first.
    Jim
    May 2005
    Oroville, CA
    +1 with AJ
    The original parts were dipped in 60-70% gloss. I have measured as high as 78% but it was old and cleaned too many times
    Powdercoat can be a little work removing and you probably should remove it for the build up issues.
    AJ will give you the best advise if you powercoat.
    H
  1. Oil Tank: Powder Coating
    By beetle08 in forum Technical Info
    Last Post: 01-28-2013, 06:35 AM
  2. Costs of powder coating
    By StephenAcworth in forum Technical Info
    Last Post: 12-14-2012, 07:30 PM
  3. powder coating
    By denson in forum General Info
    Last Post: 02-27-2012, 03:24 PM
  4. Powder coating trim
    By super9064 in forum General Info
    Last Post: 06-30-2009, 09:21 AM
  5. Powder coating a oil tank
    By John Straub in forum Technical Info
    Last Post: 05-29-2009, 12:11 PM
