Results 1 to 10 of 10
Thread: SWB Fresh Air Vent
    SWB Fresh Air Vent
    Has anyone tackled restoring the flapper valve for the fresh air vent system on a SWB? I have a few idea's, but just wanted to know if some has already found a cure.
    Thx,
    Bernie
    Bernd Buschen
    R Gruppe # 357
    71' 914-6 Original Owner
    70' 914-6 GT Stoddard Built
    69' 911E Scott's car
    70' 914-6 Sold
    Hi BernieB
    I have the same question, has anybody done this to a high degree?
    I have the same question. I cannot find anything on this anywhere.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    good morning @all
    please allow the question:
    what did you want to do?replace the rubber, or the filter?
    @bernd
    what ideas do you already have?
    best regards
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    My '67 wasn't too far gone...so I just cleaned it, treated the rubber with McGuire's and re-installed, but.....
    There are several home moulding kits for small rubber pieces...out in CA TAP Plastics sells the kits.
    So....
    Drill out the rivets, separate the shaft and cable loop, zinc plate the loop and paint the shaft.
    Make a mold of the rubber flapper and form, then re-rivet the whole thing. Yes, you can get copper rivets.
    Whew! Mine looked "good enough!" So I passed. Once it's in place no one can see it!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Thanks Mark. I have dismantled as you suggested, quite a bit of rust there so I'm going to blast the metal before repainting. Copper rivets could be a problem to find, i wonder if I can make them up out of copper nails.
    You could just as easily use aluminum rivets...easier to find, and again, Who's gonna see'em?
    When you get into the molding of a new flap..please share how it goes...photos??
    Good luck!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Try your local saddle and tack shop or Tandy leather workers shop for copper rivets or here: http://www.hansonrivet.com/
    Bob
    Early S Reg #370
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    I have rebuilt mine for my '66 912 using a product called Versimold.
    There is a metal backbone under the original rubber, which I scrapped. I blasted and repainted the tubing part after drilling out the copper rivets (which can be found on Amazon - about 8$ for 100 pieces).
    All the parts taken out of the car
    Original flap with the support tube removed
    Rubber scrapped to metal
    Versimold is a silicone paste that comes in the consistency of a rubbery puck of hard-ish Play-doh. I used a pasta machine to roll a very even thickness and then covered the metal back bone and backed it to cure. I cut it (before baking, much easier) using a template i made before scrapping the rubber from the original flap. worked very well
    I only had to then cut the holes and put new rivets in
    Baked goods:
    Name:  IMG_0646 - Copy.jpg
    Before final install of rivets
    I am pretty happy with the results
    Matt
    1965/66 912
    South Orange, NJ
    Nicely done!
    A similar product, Sugru, would probably work as well. I have used it behind weather stripping...sorta as a more permanent dum dum.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  1. Fresh air vent paint finish
    By tpdorsey in forum Technical Info
    Last Post: 04-07-2019, 09:06 PM
  2. FS: Drip Tray / Fresh Air Vent Rain for SWB 911 / 912 models
    By jos.hall in forum For Sale: 911 Parts
    Last Post: 07-21-2013, 05:48 PM
  3. Replies: 0
    Last Post: 09-10-2012, 02:19 PM
  4. Fresh air vent dash controls on a 71
    By 1971-911T-Mark in forum General Info
    Last Post: 02-12-2008, 08:06 AM
  5. WTB: cowl fresh air vent frame and grill alloy finish
    By Anthony67_911s in forum For Sale: 911 Parts
    Last Post: 02-25-2007, 01:47 AM
