Results 1 to 10 of 10
Thread: Air Box Restoration Service Rqst
    Is there anyone doing A++ Air Box Restorations?
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
    Jul 2006
    Washington D.C
    I just bought a set that has surface rusts an needed restoration as well. It will go to a local powder coater for bead blasting and a semi-gloss coat.
    Andy (VA).
    Yes, I've thought about doing that way over here in Houston. How are you going to bring the clamp mechanism back to life?
    MBR #2637
    AKA boschdog
    Houston, Texas
    Jul 2006
    Washington D.C
    Quote Originally Posted by 1968DT View Post
    I'll replate them myself, in clear and yellow zinc.
    Andy (VA).
    May 2005
    Oroville, CA
    Powder coat will not be A++
    It'll be pretty but the coating thickness is unavoidable.
    You will loose the welding/stamping.
    JMHO
    H
    Member JimVillers's Avatar
    Jul 2012
    Virginia Beach, VA
    I plated my clips with the Eastwood platting kit. They came out looking very good. I powder coated the body as was mentioned.
    Jim Villers
    Virginia Beach, VA
    1961 190SL Mercedes, 1965 230SL Mercedes, 1965 356C Porsche, 1971 MGB, 1967 911 Chassis #305119
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    I just finished mine, if you ask them to go thin on the powder coat you can maintain most of the details.
    I replated all the hardware, new seals from Porsche, and the flame trap at the back is still available new from them also.
    Tony
    Have it painted. The powder coat can be nice but if you chip it in the future it can't be touched up and is a nightmare to remove and redo.
    Agreed on have it painted. It will look less coated and more oem.
    RGruppe member 445
    Feb 2010
    San Francisco, CA
    As Harvey said, powder coating is not A++ for resto. Powder will look nice though, just not original.
    Have it blasted and painted then get the clips plated. It usually makes the most sense to generate a larger batch order for plating. You could post an ad asking if anyone is sending things out to the plater that you could join in on.
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. Service Offering: Seat belt restoration service
    By stretch in forum For Sale: 911 Parts
    Last Post: 05-02-2019, 12:50 PM
  2. Replies: 5
    Last Post: 10-26-2015, 09:07 AM
  3. FS: Service Offering - Porsche pedal set restoration service
    By bdstone914 in forum For Sale: 911 Parts
    Last Post: 05-20-2013, 10:38 AM
  4. Replies: 3
    Last Post: 11-17-2012, 10:55 PM
