Thread: Headlamp wiring question (67S USA)
    Nov 2006
    S. F. Bay Area
    Now that the wiring is installed, I'm almost finished 'proving it out'…connecting, testing and such. Using a L59 diagram (which I believe is non-USA), it shows the high-beam lamps getting power from fuses 11 and 12 via white wires. (along with the high-beam indicator lamp-white/blu). When I jump power to these terminals, I get nothing at the headlamps, although the indicator lamp is lit. Do the high beam wires go directly from the fuse panel to the lights, or do they go somewhere else first, like fog lamp relay or something? Any help, thanks
    Brian
    S Reg #1032
    from fuse to lights nonstop
    i use l57
    Nov 2006
    S. F. Bay Area
    Thanks for reply:
    Looking at both diagrams, I see no difference, and I see no "fog lamp" relay in either. Knowing that USA fog lamps go out when hi-beams are energized, I suspect that may be part of my issue.
    Tomorrow I will energize and trace my white wires and see where they lead. Thanks again
    Brian
    S Reg #1032
    Brian,
    Please see here for everything I know about SWB lighting logic. . . . enjoy
    http://www.early911sregistry.org/for...elays-Analyzed
  1. H4/H1 headlamp housings...installation question
    By mac73s in forum Technical Info
    Last Post: 08-20-2013, 08:32 AM
  2. H4 wiring question
    By POS in forum Technical Info
    Last Post: 09-09-2012, 09:21 PM
  3. Wiring Question(s)
    By Paul Schooley in forum Technical Info
    Last Post: 02-19-2008, 10:55 AM
  4. H1 headlamp bulb question
    By Wolf Knierim in forum Technical Info
    Last Post: 06-20-2003, 04:22 PM
