Results 1 to 10 of 10
Thread: Oil level wiring in the right "j" tube
    Nov 2006
    S. F. Bay Area
    Can someone please post a pic of the oil tank wiring as it exits the rear "J" tube?
    I appreciate the help. Thanks
    Brian
    S Reg #1032
    Nov 2006
    S. F. Bay Area
    Anyone able to help?
    For a swb, the rear fender supports are different left and right. (per parts book). I suspect for the tank sender wiring.
    My 2 supports are the same, so I think I need to drill a hole….but where?
    Brian
    S Reg #1032
    Dec 2008
    Woodland Hills, CA
    If you can wait until the weekend, I can shoot you a pic of my 68 with the factory S gauge option.
    right before the pinch on the bottom side if memory serves (it often doesn't)
    don't want it on the top because water wil fill up
    i can check tomorrow
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    '68 911 USA Sporto wire.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Feb 2005
    Lake Tapps, WA
    Mine looked like that on my 67S but the inner part of the J tube had rusted and I can't get the wires out
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Dec 2004
    SE Michigan
    I have a '68 that I am adding an oil tank with the level sender. Are the wires already in my harness somewhere? TIA.
    Bill G.
    EarlyS #718 | RGruppe #437
    May 2006
    CT
    Quote Originally Posted by 911scfanatic View Post
    The wires are in the tail light harness.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Oct 2010
    Southern Ca.
    The wires are in the engine comp. for swb cars .
    May 2006
    CT
    Quote Originally Posted by Richy View Post
    Thanks...I learn something new every day here.
    Tom Butler
    1973 RSR Clone
    1970 911E
  1. FS: @eBay - New level of "crazy"? P 208 offered for $911?
    By mshaver51 in forum For Sale: 911 Parts
    Last Post: 02-18-2014, 12:19 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 02-18-2012, 09:24 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
  4. WTB - 69-71 "T" engine wiring harness
    Last Post: 04-03-2010, 11:13 AM
