Thread: WTB: Front Boge Strut Cartridges for '67-'68
    Oct 2009
    Indiana
    I guess I need help on 2 levels. First, I'm looking for boge front strut cartridges for my '67-'68 911 Targa. I have a porsche part # from the book of 901-341-067-06, but it says "not for targa."
    On the second level, I've tried to cross-match the boge part # without success. I think it is a 1-0701-32-388-F, but I would appreciate confirmation that the boge # is correct from those in the community with that information.
    Please help.
    Apr 2007
    lake havasu city AZ /auburn wa.
    i have what you need a pair of koni inserts that i had in my 67 911 for about 800 miles i went to the green bilsienes so i removed these and are sitting on my shelf so they are in new condtion call 253-927-5870
    31 model A coupe
    41 Willys coupe
    70 911 T
    68 911 softie 11880049
    67 912/911 355032
    66 911 303509
    65 911 301275
    Oct 2009
    Indiana
    gregk1,
    thanks so much. please don't be offended, but i'm really trying to replace original equipment at this time. however, i will certainly keep you in mind if the boge option becomes impossible.
    thank you.
    Feb 2007
    San Diego
    I think if you want to retain Boge inserts then your closest bet is the 69+ type as seen here:
    http://www.stoddard.com/911-1965-75/...41-903-00.html
    Note that even though they say 69+ the inserts seem to have the same spec, the only difference is the length - SWB are longer and LWB are shorter. When you buy Bilsteins for SWB they come with a little spacer, maybe 1/4" tall. I would assume that the Boge for LWB should fit with a spacer. They way you would know is screw down the retaining collar - if your shock insert bounces up and down a little inside the housing then you need to space it or you will hear loud clunks in the suspension. The spacer can be fabricated easily.
    The SWB 911S targas that I have has all ran Boge struts and the rumor was the Konis were too stiff for the targa body but I doubt they were a problem.
    In the end if you want the best ride Bilstein is it, Koni and Boge are much more bouncy.
  1. WTB: Boge front strut housings for large calipers...
    By Flat Six, inc. in forum For Sale: 911 Parts
    Last Post: 03-11-2014, 02:36 PM
  2. Replies: 1
    Last Post: 02-02-2014, 09:22 AM
  3. FS: Koni Sport External Adjust front inserts for Koni or Boge strut
    By hwgunner in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 02-01-2014, 08:58 AM
  4. Wanted: L/H Boge front strut w/ 3.5" 'S' caliper spacing (70-71)
    By murph2309 in forum For Sale: 911 Parts
    Last Post: 02-21-2012, 08:09 AM
  5. FS; Koni strut inserts, pn 86-1647 for Boge strut housings
    By m1franck in forum For Sale: 911 Parts
    Last Post: 03-08-2010, 09:19 AM
